Metal cutting band saw usage?
   / Metal cutting band saw usage? #1
sdef
SC
2013 Kioti DK45SE HST
Good day. I have been reading another post on TBN about purchasing a metal cutting band saw and am getting interested in purchasing one for my new shop. I may or may not need a band saw but am certainly not adverse to purchasing a tool that can make my life easier; I fully understand the concept of "ignorance is bliss". I do typical metal work around the property- making mounts, brackets, carriers, welding repair, etc with a Miller MIG out of 1/8" - 3/8" angle and flat stock (up to ~1.75" so far), and welding 5/8" bow shackles. I am not an expert at metal work, but so far have been able to accomplish what I need to do without any real troubles with the end results strong and serviceable.
Typically I cut the metal using a 14" abrasive chop saw and am happy with it. If unable to use the chop saw I use a 60 amp plasma for cutting. I am not concerned about the cutting kerf width and clean up any cut edges with a light touch from an angle grinder, bench grinder or bench wire wheels. And none of my work will be displayed in a museum. I also have an Evolution 7.25" multi purpose chop saw but do not like it for metal cutting as the blades do not last very long and the cut metal shards make a mess- think metal sawdust if using a wood cutting chop saw.
Out of ignorance, I think that angle cutting would be a band saw's greatest benefit for me as that would be my greatest perceived need.
Questions:
- What additional ability would a metal cutting band saw provide me besides the narrow kerf and potential smoother cut?
- What size (4.5x6, 5x6, 5x8, 7x12, etc.) would be the most helpful?
- Any gotchas in band saw blades availability vs. sizes to be aware of?
- If purchasing used, anything in particular to look out for?
Thanks.
   / Metal cutting band saw usage? #2
I'll answer your questions from my experience with my metal cutting bandsaw.
1) fairly quiet and now where near as dirty and nasty as an abrasive blade (that alone is enough reason to own one)
2) I have a 4.5 x 6 HF cheapie, I use Olson blades I get at TSC , not bad price wise and they seem to last a fair amount of time. The ones I get are for thinner metals (less than 1/4")
3) I've only used the Oslons so I can't help ya there
4) watch for worn bearings, the blade (at least on mine) rides on bearings.
The thing I like most I think is the fact that you can do something else while it's cutting, I wouldn't leave the shop but you can be grinding one piece in preparation while the other piece is being cut. One thing to keep in mind is if you need to cut long stock you are going to need some sort of supports at either end.
You won't regret owning one. I am going to buy a bigger one in the future, with coolant and hydraulic feed.
Another thing that just came to mind is make sure the area you are going to cut is rust free, rust will kill the blades.
   / Metal cutting band saw usage? #3
The bigger the saw you can afford, the better. I don't like noisy stinky chop saws myself.
I have used the larger saws for years where I work. The only problem I have ever had with them is applying too much cutting pressure on the blade, and stripping the teeth off a bi-metal blade. One tooth broke off in your material will ruin the blade quickly unless you catch it in time.
All I have at home is one of those small 4x6 saws that I bought off one of those tool trucks. It's basically the same thing that harbor freight sells(their smaller one). I have cut ALOT of metal with this saw. And it can be converted to vertical which I use also.
Let me tell you the mindset you need before buying from harbor freight; You go around and look at all your choices, if you have the money you can get a nice used saw. If you don't have the money you start looking on the internet and start finding people fabricating their own saws. Then you start figuring the time and materials to make your own saw. Then you look at the harbor freight stuff and think to yourself, "instead of making my own saw, why not start with that". That's the way you have to look at it if yo buy from them you are getting a head start, but you still have to mess with it and do some changes to make it a good saw. If you go in there with this attitude on stuff you buy there, you won't be disappointed.
On my cheap saw I had to shim the gearbox so the blade would not keep coming off, I made thicker table for when you use the saw vertically, and I modified the guard so I could cut a little bit larger piece of metal. I also made a frame for the bottom and put wheels on it so I could tilt it up and move it around and support the saw better than those thin sheetmetal legs. After all you are sort of in the fab business, so any of these minor mods are a piece of cake. This has been a good saw for me, and the blades are available at of course harbor freight, northern tool, and tractor supply.
   / Metal cutting band saw usage? #4
I've had my 7x12 import saw for 18 years now. I ditched the coolant system and get excellent results using a lube stick. Quality blades are important. I like Starrett.
I also added a reduction gearbox and bi-metal blade to a 14" vertical bandsaw for cutting steel.
And this little guy I keep at wood cutting speed for aluminum.
Terry
   / Metal cutting band saw usage? #5
as others have stated.... no dirty cutoff sparks all over the dam place. and a more accurate cuts as those abrasive blades are known to flex a little... just buy one you will be happy... different blade pitches can be used for different sizes of steel but it sounds like your into pretty light stuff anyhow! these things make the cut and turn the saw off when there done...you can be doing something else in the other end of the shop well its cutting! I use band aid lubricant by lennox... seem s to do the trick. blades last a long time as a hobbyist (years)
   / Metal cutting band saw usage? #6
Have you thought about a portable band saw? That's usually my go to saw for cutting metal. I have always wanted to get a horizontal cutting band saw but never got around to it. Each time I get close I wonder if it would just be in the corner requiring me to dig it out. For a large project I don't think it would be an issue but for small stuff I can do a great job with my Milwaukee and a vice. Plus with a portable saw you can make finesse cuts that would be difficult on a regular band saw. That doesn't mean I wouldn't like a nice horizontal floor saw as a complement. I'm pretty accurate at cutting straight lines but not perfect.
davedj1- Yep, the noise and air pollution is a good point and this first comment nudged me quite a bit closer to the purchase.
franklin2- Agree 100%. Actually I try and purchase very little from HFT these days as the quality on motorized tools has gone downhill over the years. Same thing with Sears. In general I like the HFT metal, such as G70 chain and trailer hitch components. My go-to for less expensive power tools these days generally come from Northern Tool but I can be persuaded to purchase HFT if the bang for the buck is there with sales plus 20% coupons. My last HFT power tool purchase (~5 years ago) was a 12" compound, sliding miter saw I could not adjust to get a square cut.
Big Barn- Nice looking shop and thanks for the blade recommendation. I always invest in higher quality cutting surfaces for anything I use and was not aware Starrett made band saw blades.
notme- You guys have convinced I need to upgrade my primary cutting device.
crazyal- Yes I have considered a portable unit and actually almost purchased one before I got the plasma cutter. I think in general the plasma is the best portable cutter for my usage.
- Concerning the stick lube mentioned twice, is this really a good replacement for an oil bath?
- Any opinions on the lesser band saws sold by Northern Tool such as:
http://www.northerntool.com/shop/tools/product_200659143_200659143
http://www.northerntool.com/shop/tools/product_200323677_200323677
   / Metal cutting band saw usage? #8
I bought a 7 X 12 from ENCO about 15 years ago and I love it.
I have never used the coolant system and don't figure I have ever needed it.
I have used saws with it and feel the mess isn't worth the difference.
I have rigged the horizontal table so I can insert or remove easily (no bolts or screws) and being easy to put on I use it about 50% of the time!
I will cut PVC or rubber or small wood with it too.
I had a 4 X 6 for about 30 years and didn't use it since I bought the 7 X 12.
Last fall I gave the 4 X 6 to a friend.
He did sell me a Polaris 330 four wheeler for $300. needing repair so I told him the saw was a "rebate". :)
You will find a use for it.
I am a bit leery of oil coolant since I will be welding after cutting and an oil bath may just complicate cleaning. If a dry lube/stick lube works well, I am good.
   / Metal cutting band saw usage? #10
I have an older horizontal bandsaw. That brand from Three Rivers Michigan. It's not the smallest, but I have had a lot of trouble not having the clearances to get the angles I wanted. Something is always in the way. I built a cart with castors so it gets out of way when not needed. Much better than a abrasive saw although I sometimes find it quicker to get out the chop saw.
A friend just got a Vertical band saw, where the carriage moves under spring tension. It also has a foot lever. Never seen anything like it.
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2014 Ford F-250 (A55973)
2014 Ford F-250...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
