Today's Welding time!
/ Today's Welding time! #21
My recollection of 1/16" stick welding (from 40 years ago).
Stick welding even 3/32" is difficult. You barely feel the flux on a 3/32, there's none of that feedback on 1/16. . 1/16" is an exercise in patience. Most stick welders don't consider items less than 1/8" thick as even "repairable". 1/8" rod is the minimum - if 1/8 rod can't fix it its not fixable. If you can get 1/16" stick-welding to work at all - you probably have the dexterity and control to consider TIG as "easy".
Well there ya go. A free pass to buying a TIG rig!! :D
Just watch that duty cycle!!!
:laughing::laughing::laughing:
Ooops ..... Agreed if you want capability to weld 1/4" Aluminum then its a bigger (AC) machine. And aluminum tends to be thicker materials.
/ Today's Welding time! #22
Yeah, I don't see myself welding nearly enough to justify that ... at least not at this point. I'm really just having fun developing a new skill. I like the challenge of stick.
/ Today's Welding time! #23
Working on a stand for my new to me leg vise.
/ Today's Welding time! #25
I like that!
I need to make something similar - and I have a 15" automotive wheel for the base. Has anyone done this, and can recommend it?
Using a wheel makes it easy to tilt and roll into position. Personally, I find them functional but aesthetically unappealing. (butt ugly). :)
Edit: I didn't mean to sound critical about the wheel idea. It's just that's there's so many more creative ways to do it utilizing recycled materials.
Seen some that spin as well but I agree.. ugly.
/ Today's Welding time! #27
Maybe I should paint it then? :D
Functional is the primary objective. Aesthetics ... well ... would be overkill in this 'shop'. It's a simple barn stall intended for parking equipment, so simple that it had a dirt floor for the first 50 years.
I need to roll the welder (and big vise) out in front of the stall to weld away from everything flammable so an easily movable vise will be an improvement.
80655d1183741444-changing-hydraulic-fluids-huge-drain-p1120036rsiphon-jpg
/ Today's Welding time! #28
Aesthetics are NEVER overkill IMO. :)
Terry
/ Today's Welding time! #30
best little grinder stand I have seen is in my buddies shop. He took a 1 ton rear brake hub. welded a little reebar inside it and filled with concrete. Made plate to bolt to the lug bolts and welded a tube for the upright that the grinder sets on. the weight of the concrete makes it stable and if he wants to move it, it just tilts it on the edge and rolls it to where he wants it.
I used a large engine flywheel to make my grinder stand.
/ Today's Welding time! #32
Hope you won't mind if I steal some ideas from you, especially like hardy storage solution! Great job.
Absolutely!
FYI the post vice stand is a cast iron water pipe filled with rebar and 250 # of concrete. Lengths of 3/4" all thread protrude out the top so that the table can be changed out for something else in the future.
I've standardized all my hardies to have 1.25" square shanks. The 3/8" plate holder has 1 5/8" round holes for storing them.
Terry
/ Today's Welding time! #33
Finished my stand today and mounted the vise. Had to use the 2x10's because the vertical 2x3 steel I had on hand was too short.
/ Today's Welding time! #35
Where do you fellers get those cool vises?
Those are blacksmith style vises, I think. I saw a couple for sale once at a local used tool store for crazy $$$. They are cool to collectors too, apparently! I would love to stumble on one at a garage sale...
/ Today's Welding time! #38
Sodo, use the search term "post vise" when you're lookin' - but be prepared to spend as much (or more) than new "regular" vises, I sometimes wonder if they are made from the same "un-obtainium" ANVILS are :eek: ..Steve
/ Today's Welding time! #39
My post vise came from Dad scouring every Estate Sale he saw listed, for years after he retired. I inherited the post vise and another Columbia bench vise at least as large, plus a large and medium Craftsman, and several smaller vises, all bought for what had to have been under $10 each or he wouldn't have bought them. Yard-saleing every weekend in the city was his entertainment. I don't think there is any other way to find those old vises for less than antique-store or Ebay price.
I visit yard sales far less frequently but I found my $50 Wards PowerKraft 230amp AC stick welder (tombstone equivalent) at a neighbor's estate sale. (Now that I have a TIG/DC stick welder as well a mig, I expect to use this antique less).
34734d1110327824-fuel-efficient-vehicles-reasonably-safe-600595-cars-trailerimg_3004-jpg
/ Today's Welding time! #40
They're also known as a blacksmith vise. Also search using both vise and vice!
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
LOOK! (A63111)
LOOK! (A63111)
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
