Snow chains, too close to the body
   / Snow chains, too close to the body #13
If it's just for chain clearance I'd stay in the 2" range. Much wider and you could affect the implement coverage/width.
Fighting roughly a foot of snow with just the front (aggressive) chains today. These really affect the ride on pavement (or ground/gravel once you clear the snow)
Tractor struggled up the hill (but managed, we have 20%-30% inclines), could definitely use more traction.
   / Snow chains, too close to the body #15
I ran into this same problem this year. I have a kubota L3010 with the same size R4 tires. Instead of paying for spacers your wheels should be adjustable. Cost me $100 in labor to have the local dealer take the wheels off, turn them around and move them to the opposite side giving me the clearance necessary for chains.
Let me dig up the thread
   / Snow chains, too close to the body #17
..Instead of paying for spacers your wheels should be adjustable....
L3430 is a Grand L and has adjustable rims, show us a photo of the side of the rear wheels. They should have bolts and they can be set in several widths!!!
PS KILLER tire chains!!! :D
   / Snow chains, too close to the body #18
Why would a tractor manufacturer make a tractor you can't put chains on?
   / Snow chains, too close to the body #19
Trust me they do..On my Kioti I didn't have much more space than that. I took off the tensioner on the inside and instead of using that shackle, used a chain "quick link" instead.
The chain tension is still achieved by the tension link lever on the outside, as it pulls the chain tight up against the tire. I only have 1/2 inch at most of clearance, but it is enough.
   / Snow chains, too close to the body #20
All "standard" economical "L" model R4 tires are non adjustable... they do NOT work with chains (so yes, some companies will do it...) My guess is they are trying to make you upgrade to the Grand L...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
2005 PETERBILT 379 (A58214)
2005 PETERBILT 379...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
LARGE LOT OF CHAIRS & HAND TRUCK (A58374)
LARGE LOT OF...
PALADIN INDUSTRIAL SCREENER (A58216)
PALADIN INDUSTRIAL...
