FEL Frame Damage From Snowplow Use.
/ FEL Frame Damage From Snowplow Use. #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Back in the 1980's, there were few commercially available FEL mounted snow plow attachments for small compact tractors. I used a 60" front frame mount snow blade on my B7100 HST for a couple of seasons but found I wasn't able to pile snow high enough to get it out of the way. I eventually built a snowplow attachment for the tractor's FEL. I modified an old Jeep plow by cutting it down to a 66" width. I added brackets to attach the plow frame to the loader arms and made up a 3rd function valve for power angle. The setup worked very well until the second season when I broke several welds on the FEL frame.
The "shop talk" back then was that FEL's on compact tractors weren't strong enough to handle the side load generated by an angled snow plow blade. Based on this, and my own experience, I stayed away from FEL mounted plows. I really miss the convenience and versatility of that FEL plow though. I used to be able to pile snow 15 feet high with that little 17 HP tractor. I could clear my 1/4 mile driveway in half the time it took with my pickup.
Now, 35 years and four Kubota's later, I see FEL plows are quite popular. I assume FEL designs now take side load into account and I'm considering one for my MX5800 and LA1065 FEL. With the large number of our members here who use them, I'm curious if any have experienced FEL damage from snowplow use.
/ FEL Frame Damage From Snowplow Use. #2
/ FEL Frame Damage From Snowplow Use. #3
With a trip edge and cross-over relief valve and floating plow;I believe a FEL mounted plow is safe for loader use.I have had no problems with my FEL mounted plow(at least the FEL part).I had converted an old truck plow and broke part of the plow frame itself but repaired and have not had further problems.
/ FEL Frame Damage From Snowplow Use. #4
There's more to it than that, I think. In the 1960's I did quite a bit of plowing with a Jeep. A constant problem with the plow back then was tagging unseen curbs, parking guides, etc. with the plow, usually snapping the blade angle pin (hydraulic angle plumbing was pretty new back then). If you do any commercial work, it's hard to avoid such impacts. I've often wondered how those with FEL-mounted snow blades avoid hitting immovable objects buried under the snow. With the blade so far out in front, such hits have to send an extreme shock load to the FEL frame.
/ FEL Frame Damage From Snowplow Use. #5
I had B7100HST w/72" plow frame attach to bucket for 14 years plow snow work great no damage.
Float and trip spring most important.
7th winter same setup with 7' 6" plow on L2800 does great.
/ FEL Frame Damage From Snowplow Use. #6
FEL damage is certainly possible, but its not like these FEL's are made of glass. I've been running a heavy FFC 8ft V-plow (over 1,000 lbs) for several winters in a rocky environment on an MX5100 with no damage. It has a trip edge and float, but I've hit rocks out on the end of the blade above the trip edge hard enough to either 1) swing the entire back end of the tractor around by a couple feet or 2) Push the blade back, which means the sequencing valve had some cross-over function (intended or not, its not clear to me). No detectable damage.
/ FEL Frame Damage From Snowplow Use. #7
Loader is LA844.
/ FEL Frame Damage From Snowplow Use. #9
I've been running snow plow on my DK 35 loader for the last 16 years with no issues.
Running a 9' converted Western truck plow.
/ FEL Frame Damage From Snowplow Use. #10
Damage is possible anytime you use your tractor, especially moving snow, no matter what setup you use.
If a FEL mounted plow is properly sprung, you know your area well, have mitigated potential hazards, and can exercise some degree of control, you will probably be fine.
Someone who tears stuff up all the time should probably hire someone anyway.
I have used my FEL mounted plow for many years without damage.
I chose to remove the bucket, and made a mount to go directly on the arms with the plow.
I would never want a frame mounted plow, after seeing how much more versatile a FEL mounted plow is.
/ FEL Frame Damage From Snowplow Use. #11
No issues with my 7.5' Meyer on my mx
/ FEL Frame Damage From Snowplow Use. #12
I damaged the loader on my DK-35 Kioti, NOT from snowplowing; mostly from lack of experience running a tractor with a FEL.
I traded up to my current DK-40 and a much beefier FEL. I then got the HLA model 2000 72" snowplow, noted in my signature. It has a built in crossover valve, and single large piston, and is designed for FEL use. Check out their website to get an idea of the massive amount of plow equipment they design and sell.
It is MHO that plow use on a FEL depends on several factors. Type of use, commercial or home/farm, etc. Also, how the terrain being plowed is marked with driveway stakes, etc. And skill level of the tractor operator/owner, and time available to not rush the desired results. That being said, I think a strong FEL, capable of pushing a properly specked out, suitable to machine sized blade is essential.
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
CAT 140M Motor Grader (A64047)
CAT 140M Motor...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
DRAGON TRAILER MOUNTED TRANSFER PUMP (A63569)
DRAGON TRAILER...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
