thickest 2x2 square tube to fit receiver hitch
   / thickest 2x2 square tube to fit receiver hitch #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
What is the thickest square tube that would fit a receiver hitch (please don't say solid). This will be used on a subsoiler on the back of my counter weight.I tried a piece of 11ga. I got from work and it bent.Need thicker wall tubing.Will 2x2 1/4" fit in the receiver? Thanks for the help. 100_9667.JPG
   / thickest 2x2 square tube to fit receiver hitch #2
Isn't tubing sized by the OD (outer dimension)? 2x2x1/4 or 2x2x3/8 or 2x2x1/8 are all 2x2 on the outside....Or am i missing something here?
   / thickest 2x2 square tube to fit receiver hitch #3
That's how it is in Missouri. :D
The thicker the wall, it looks like the outside corners are more rounded. I don't work with a lot of structural square tubing.Want to get help from someone that does.I may be missing something too, That is why I asked!
   / thickest 2x2 square tube to fit receiver hitch #5
I've built several. Usually use 1/4" wall.
Where a problem appears is if you try to use normal square tubing to make the female part.
   / thickest 2x2 square tube to fit receiver hitch #6
I built a hitch for my truck and used 2x2x1/4".
   / thickest 2x2 square tube to fit receiver hitch #7
Why not use solid bar stock?
I have trailer hitches made from it & they work fine.
   / thickest 2x2 square tube to fit receiver hitch #8
Yup, any 2x2 square tube will fit in a receiver hitch, as square tube is on the outside dimensions, not the inside like Pipe.
In 2x2, it appears 1/4" wall is the thickest offered.
I did make one from solid for a truck (what we had on hand at the shop)I was trying to cut down on the smart a** comments.I wanted to make sure the 2x2 1/4" would the best with the receiver. Thanks for the help!
   / thickest 2x2 square tube to fit receiver hitch #10
Why do you want hollow tubing instead of solid on a subsoiler? Just asking.
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
