L40 Cab owners-- what is this elec. connector?
/ L40 Cab owners-- what is this elec. connector? #1
FatTire
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
This connector is hanging out to the rear of the door pillar, left hand side. That's the left rear side window behind it. Wires are black and yellow. The prong is bent, so it sorta looks like previous owner had something plugged into. Anybody recognize it?
Thanks,
Dave
/ L40 Cab owners-- what is this elec. connector? #2
Just for grins, put a volt ohmmeter on it and see if it is 12 volt power. Also see if it is switched power. Previous owner may have had a fan or something like that.
That's what I would normally do, but broke my leg a week ago. Suddenly my shop seems distant, and even simple tasks are a hassle. I was just thinking that if this is a factory connector someone might immediately recognize it. I can't picture any factory option that would mount there. The window defrost connectors are up on top.
/ L40 Cab owners-- what is this elec. connector? #4
My 60 series cab has the same connector in the same place. I recall reading somewhere it was 12v on the ignition switch. I will test it tomorrow and follow up.
/ L40 Cab owners-- what is this elec. connector? #5
It looks like a rear window defogger plug in. Do you have them on both sides?
Its only on the left. The big rear window has a defroster, it is hooked up with wire lugs (not a plastic connector) on black and yellow wires. The same wire connectors on blk & yel are hanging out at the ceiling where they would connect to the side windows, but those windows don't have the defrosters. I wonder if that is not "normal"? Maybe I can ask my wife to find my DVM and bring the tractor closer to the house and I could see if/when it is energized. It would be fun just to sit in it. Brand new (to me) and I can't do anything, so frustrating.
/ L40 Cab owners-- what is this elec. connector? #7
Our open station L3830 has the same plug in the back with the same colors. It is supposed to be used for a rear work light or something. It is switched to turn on when the key is on.
Aaron Z
Aaron Z
Hmmm... Wonder what I should use that power for? Maybe I'll just tap into those wires up near the dash for a rear view cam.
/ L40 Cab owners-- what is this elec. connector? #9
I think it's for defrost. I believe mine has them.
When I added rear lights all the wiring was there.
These wires probably go to the overhead switch area, and there is probably power available there.
/ L40 Cab owners-- what is this elec. connector? #10
Sure don't mean to derail this thread, but is your rear defroster inside the rear glass or applied to it? My 5030HSTC had wires in the glass and my 5740HSTC is applied so I can't use window tint.
/ L40 Cab owners-- what is this elec. connector? #11
My L3200 had that plug under the fender & my new L4060 has that plug in the same place on the left pillar. I have the rear window defroster (dealer said it's actually a whole new rear window with the heater elements in it) & it doesn't use that plug. As the L3200 didn't ever have a cab option I'm pretty sure defroster can be ruled out.
I'm pretty sure it's just a spare accessory wire. I think Original 2 pin Power connector for VHF/UHF Power cords - Power source side | Powerwerx is the plug. Don't remember if that's the same plug or mating plug offhand.
/ L40 Cab owners-- what is this elec. connector? #12
The one on our L3830 is that side (the female side).
Aaron Z
Yes, mine is on the surface too. Are your defroster connections at the top?
/ L40 Cab owners-- what is this elec. connector? #14
Haven't had a chance to look, but the window hinges are on the top & no wires dangle, so the connection must be up there in the roof.
/ L40 Cab owners-- what is this elec. connector? #15
I also have a 4060 and asked the dealer about it when I received the tractor. The dealer could not
answer my question. I also purchased a shop manual for the 4060. I believe the plug is part of
the cigarette lighter circuit, and as such is controlled by the ignition switch . I have an electrical
accessory that I have used this circuit to energize and it works just fine. Also don't rely on your
dealer to buy the mate for the connector, it's not on their parts list. I bought a new connector set
at the former Radio Shack and replaced the whole unit to fit my need
/ L40 Cab owners-- what is this elec. connector? #16
/ L40 Cab owners-- what is this elec. connector? #17
Got the same plug on my L 3940 . Good to know
/ L40 Cab owners-- what is this elec. connector? #18
I was told by my dealer (old school ag dealer) that it is just an aux. power source for supplying power to things such as a 2 way radio, or other fancy monitors used in today's modern tractors.
/ L40 Cab owners-- what is this elec. connector? #19
On the open station, there is a work light kit that will plug into that. From what I can see the Kubota part number is 3A011-75904 and Messick's wants $132ish for it.
Aaron Z
/ L40 Cab owners-- what is this elec. connector? #20
I was told by the dealer it was for the rear window defrost which is similar to an automobile style rear window defrost. (Not circulated air)
2023 HarbinGer V3 Plus S/A Towable Light Tower (A60352)
2023 HarbinGer V3...
Vertical Steel Well Tank (A61570)
Vertical Steel...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2013 Komatsu PC210 Excavator (A60352)
2013 Komatsu PC210...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
