New MDC7060 12 speed 4 wheel drive light question
/ New MDC7060 12 speed 4 wheel drive light question #11
I think rustyshackelford is right, I remember reading about that in a piece of Kubota literature hoping that my tractor had this. No such luck, my tractor was the previous year. Nice feature! I pulled this off (internet) literature from a bigger Kubota
"Brake type: Hydraulically operated wet disc brakes, with automatic front axle engagement (4WD) (The front axle is engaged automatically for braking purposes when both brake pedals are pressed together, regardless of whether 4WD or 2WD is activated)"
Well one things for sure....either my tractor is correct..... or mbu's tractor is correct.
/ New MDC7060 12 speed 4 wheel drive light question #13
Yep. I'm anxious to hear the answer. Are they the same model year? Obviously his is a '16. Sometimes model year gets a bit confusing, especially at a time when two model years could easily be on the lot together.
Let us know what you find out. :)
/ New MDC7060 12 speed 4 wheel drive light question #14
Next time it snows down in FL, slam on the brakes at about 10 mph in 2wd and see what you get :laughing:
/ New MDC7060 12 speed 4 wheel drive light question #15
We know what we get don't we Eric!!!! :eek:
/ New MDC7060 12 speed 4 wheel drive light question #16
Uh oh, just remembered that the literature I first spoke about was for an M9540, and the on line one above is from a M135. Well the do offer it, on some models:confused3:
/ New MDC7060 12 speed 4 wheel drive light question #17
I'm going to say that both tractors are operating as designed, you can have the same model , but have changes in the design. Very common with tractors, when ordering a part you have to have the serial number because they have changed a design or a part in the middle of the series production.
/ New MDC7060 12 speed 4 wheel drive light question #18
I agree. I think this will be the technical answer to this issue? :)
/ New MDC7060 12 speed 4 wheel drive light question #19
I think Richard was on to something with one being electronic engagement. Does one have a Lever for 4wd and one have a rocker or switch? With the lever, it obviously wouldn't automatically engage but if it's electronic, that would be the ticket. I'm about 99.9% your tractor is operating as designed
Brett
/ New MDC7060 12 speed 4 wheel drive light question #20
All four wheel drive tractors with electro-hydaulic engagement will have this feature. It should only work with the brake pedals locked together. It is a safety issue so you have better braking especially with a front loader.
Some models with have the light come on with brakes others don't. Depends on the build date.
2022 Ford F-150 Ext. Cab Pickup Truck (A59230)
2022 Ford F-150...
DEUTZ MARATHON...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
2007 Ford F750 Bucket Truck (A60352)
2007 Ford F750...
2014 Ford Transit Connect Passenger Van (A59230)
2014 Ford Transit...
