Code54
Elite Member
- Joined
- Aug 20, 2005
- Messages
- 4,420
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I finally started putting together a 6' land plane (mostly out of extra metal we have around) and was wanting everyones thoughts and ideas?
It is 62" long and 6' wide. Thinking I would like to get around 12" high. (any thoughts)
Straight or angled blades ( I am leaning toward straight - easy to make highly adjustable )
How far below the side edges should the cutting blades extend down?
Roughly what angle should I slope the blade back at?
I currently only have one cutting blade - do I NEED two - instead of a second cutting edge I have seen an adj. piece of channel used? Does it work ok?
I am thinking the front blade will do the cutting and the second would do the spreading? I am also kicking around adding 6 rippers to the front - just in case
