1963 Ford 2000 electrical problem
   / 1963 Ford 2000 electrical problem #1
john357
Jennings, La.
1963 Ford 2000 4-cyl. gas, 8N, JD 4630, 4230, 3020, R, 60, D.,
I have a 1963 Ford 2000 4-cyl. gas. it has been converted to 12 volt, one wire alternator. New battery, starters good, relay's good. I can't get power through the relay to the starter. I've even taken a jumper cable from the battery to bypass the relay and nothing happens. Really scratching my head on this one. When I turn on the switch I have power to three poles on the relay, pushing the starter button grounds it out as usual, so that should be good. But here is something that is quite confusing to me. When I turn the switch on and then turn on the light switch I loose all power going to the relay. The battery post is hot but the cable attached to it is not. I really don't know what is going on. Could this be a grounding problem or some kind of polarity issue? Would appreciate the help, thank you.
   / 1963 Ford 2000 electrical problem #2
Is it a 3 or 4 wire relay?
Either one will have 2 large cables going to it. One coming from the battery, one going out to the starter. Verify with a volt meter that you have 12V at the relay coming FROM the battery.
Assuming its a 3-wire relay, you will have one small wire. This wire gets energized to close the contacts and allow high current to flow through the relay. BUT the relay has to be grounded. Usually grounded through its mount.
So apply 12v (can be with a jumper wire) to the relay. Do you hear it "click"? if you dont hear it click, check how its grounded.
Be careful doing this and it wouldnt hurt to unhook the battery cable feeding the relay. Because this is bypassing all the safety stuff and if the tractor is in gear it may still try to start.
   / 1963 Ford 2000 electrical problem #3
He should ( I know.... I know. ) have a 4 wire relay. 2 big, one bat, one starter, 2 small, one key, one thumb button.
Loosing power with lamps on, and hot post at bat, but not on cable is classic poor connection issue.
OP, clean bat posts and cable ends, check for corrosion at cable to terminal, fo it yourself replacement ends are notorious for this.
Lastly, if your headlamps run thru your ignition switch, you may be overloading the switch and or its feed wire.
Consider running a good heavy new clean wire for the ignition switch feed, and run a separate wire to the lamp switch so that it is not going thru the ignition switch.
Ign switch should just sent power to the coil, and the start relay.
4 post relay. Tested relay it clicks. I took off all the cables and shined them up. I have lights now! But now i'm only getting power to the "I" terminal and not the "s". So no crank.
4 post. It clicks but still no crank.
   / 1963 Ford 2000 electrical problem #6
I think that is your issue. You have the wrong starter relay/solenoid.
The 4-post relay with an I-terminal was a ford automotive thing. I may be wrong but not sure it was used on tractors. The I terminals was to power the ignition and NOT a ground terminal for the start push button.
You need a 4-wire relay where the 4th terminal is a ground to activate the relay and NOT an "I" terminal
ok, I'll go to my local Ford dealership tomorrow and order one, probably take a few days to come in cause I know they won't have one in stock. Thanks
   / 1963 Ford 2000 electrical problem #8
Is that indeed how you had it wired? With the start switch wired to the I terminal?
Those relays still ground through the base. Where is it mounted? If it's mounted where it has a good ground, I am surprised it's not trying to crank as soon as you apply power to the S terminal.
A local auto parts store should have 4-wire relays that will work. Just make sure the 4th post isn't an I terminal, rather a ground. Might not be labeled. Might have to read the little paper that comes in the box to confirm
   / 1963 Ford 2000 electrical problem #9
Napa will have a 4 terminal isolated base relay
   / 1963 Ford 2000 electrical problem #10
Ps, actually check the relay.. Is the coil between 1 small and base, or both small.
2011 WESTERN STAR 4900 SB (A50854)
2011 WESTERN STAR...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2002 PETERBILT 330 CARGO TRUCK (A50854)
2002 PETERBILT 330...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
