2001 John Deere 790 4X4 Electrical Problem.
/ 2001 John Deere 790 4X4 Electrical Problem. #1
Paul5150
Sacramento, Ca
2001 John Deere 790
Does anyone have good electrical diagnosis expertise on an electrical problem I'm having with my 2001 John Deere 790? My engine temperature gauge will not work unless my fuel tank is 1/2 tank full or higher. Once it drops below the 1/2 level, the needle on the temperature gauge drops all the way to the bottom of the gauge and doesn't move. The only thing I can think is causing this is that somehow the engine temperature circuit is being grounded thru the fuel gauge circuit. Any ideas?
/ 2001 John Deere 790 4X4 Electrical Problem. #2
:welcome: to TBN
My first suggestion would be look for a copy of the service tech manual, that will have the schematics for the electrical circuitry.
Sounds like you may have a clue with your grounding thoughts.
/ 2001 John Deere 790 4X4 Electrical Problem. #3
Sender unit more than likely. Check the resistance with a volt Ohm meter.
/ 2001 John Deere 790 4X4 Electrical Problem. #4
I have a PDF of the tech manual you're welcome to, if wanted shoot me your email
Joe
Joe
Thanks, I have the repair manual already that includes the electrical diagram. If I ground the wire going to the temp sender unit, the gauge pegs all the way up to hot. If I keep at least a half a tank or higher of fuel in the fuel tank, the temp gauge works fine. I'm thinking that the temp sender unit and the wire are good. I'm leaning towards a problem with the gauge being that its a soldered circuit board that includes all of the other gauges together. The bad news is that I might have to replace the whole instrument panel that costs over $500
/ 2001 John Deere 790 4X4 Electrical Problem. #6
Some how I misread your post, sorry. I would check the grounds on the panel, etc. Sometimes a faulty ground can do some strange things.
Thanks. I'm trying to gain access to the back of the instrument panel, but I can't get the steering wheel off.
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
2021 John Deere 3025E (A64911)
2021 John Deere...
2016 Ford F-150 XLT (A64911)
2016 Ford F-150...
Mahindra 4550-4L Loader (A64911)
Mahindra 4550-4L...
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
