Cutting Lube
/ Cutting Lube #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I bought a small set of broaches (annular cutters) for cutting sheet metal and thicker steel. I also bought two tubes of the recommended stick lube. They are 1.68 ounces each and with tax and shipping they cost $20! I found a better deal for a 1 pound tube of cutting lube but it is $36 to get it to me.
Is there a cheaper way? Or a cheaper outlet for the waxy stick grease? Can I get away with using wheel bearing grease without burning up the annular cutters? I am also thinking the wheel bearing grease would fly away making a big mess.
/ Cutting Lube #2
I don't do much cutting and have never used a good lube. :( I'm looking forward to hearing what people in the know use.
/ Cutting Lube #3
Go to a plumbing supply and get some pipe cutting oil. They use it when they have to cut pipe threads on galvanized pipe.
/ Cutting Lube
I've got cutting oil. It makes a mess, especially if i'm drilling horizontally. That is why I would like to find an affordable waxy grease.
/ Cutting Lube #5
One of the old standards was lard. Candle or canning wax was sometimes used, too.
Bruce
/ Cutting Lube
Bruce
Paraffin is cheap enough. People used it for cutting oil?
/ Cutting Lube #7
Here's one of the references I found.
Bruce
/ Cutting Lube #8
Here are my two favorites.
Terry
/ Cutting Lube #10
That looks quick and easy but still messy and $12 per can.
Using the nozzle I can apply it sparingly, but messy, yes.
(I'm also quick and easy, but cheap).
Terry
/ Cutting Lube #11
bigtlller I use sheet metal cutters (shallow annular cutters) for holes
in material 1/8" and thinner. A stream of compressed air is all I use to keep the cutter cool and to clear chips.
For annular cutters up to 3" DOC I use the aforementioned spray coolant. It is a clingy foam and works well on horizontal holes.
Terry
/ Cutting Lube #13
I've switched to a water based cutting fluid. A drop every now & then (like 4 during a 1" hole through 1/2" steel) works very well and no oily mess. I get it at the welding & gas supply house. The bottle (16oz?) comes partially full and you add water to top it off. Iirc $12 or so, not expensive enough to be notable.
/ Cutting Lube #14
Try Boelube. They sell it at MSC is various sizes and configurations. Boelube at MSC
/ Cutting Lube
I found a place that sells the Blair 11750 Rotabroach Stick Lubricant for $1.67 a tube less than my original order, so I bought 10 tubes and only $7 for shipping. That should last about as long as the cutters.
/ Cutting Lube #17
/ Cutting Lube
That looks like a great product for a bandsaw or any dry cut saw, and it's only $15 for a 1lb tube.
/ Cutting Lube #19
/ Cutting Lube
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
5 Wheel Hay Rake (A65640)
5 Wheel Hay Rake...
New/Unused 3 Point Receiver Hitch Attachment with Gooseneck Ball (A65583)
New/Unused 3 Point...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
White 5100 4R Planter (A66408)
White 5100 4R...
(3) Wheels and Tires for 4-Wheeler (A65579)
(3) Wheels and...
