Ford 4000 alternator
/ Ford 4000 alternator #1
Con4000
Co Tyrone
72 ford 4000
Hello, I've decided to convert my ford 4000 to alternator as the Genny isn't cutting it, I'm just wondering can someone give me a run down on how to wire the alternator in correctly, this model has 3 spade connectors on the back 2 big and 1 small I'm presuming the small is battery light and one big spade is charge to battery? Thanks
/ Ford 4000 alternator #2
C'mon, really?
Suppose maybe you give us a small clue as to what brand and maybe even model of alternator it is?
Or perhaps that plus a picture of the back of the alternator?
With what you have provided, you might as well ask for a miracle. In fact, you did.
/ Ford 4000 alternator #3
Do you have an aux tach drive, or are you planning on loosing your tach to go to a common alternator?
You coil get an alt with tach drive. They used to be spendy, and were external reg gm 10dn I think. Someone makes a 10si converted one with worm drive now.
I'd abandon your Genny wiring and re hook other side of the vreg, making your connections there.
/ Ford 4000 alternator #4
Did you get one with an internal or external regulator
Hi, my bad on the lack of info Rickb the alternator is made by qtp(quality tractor parts ) it's a 45amp alternator with a built in regulator I'll try to post pics if it now, as regard the tach drive I have fitted a new oil pump drive gear with the drive unit so I can run my dash from there, I have also fitted a new anticlockwise dash so all is good on that end it's just the cable hook up I'm unsure of
/ Ford 4000 alternator #7
When I converted my 4000, the alternator came with clear and concise instructions and pics. I would assume the one you order will also.
/ Ford 4000 alternator #8
Quality Tractor Parts[]=1093,1117,1270#1093 here is the link to the alternator if it helps
Your link doesn't work. even using their filtering by make / model.. i don't see anything but ford new holland, and your model is not listed.
The only 45a model I see is their 2421P
/ Ford 4000 alternator #9
Hi, sorry for the late replys I got locked out of my account and had to make another one! Yes soundguy you are correct my alternator is the 2421p it is listed for the 4000 under tractor compatibility
/ Ford 4000 alternator #10
Did they show an associated wire harness adapter or ?
/ Ford 4000 alternator #11
They showed nothing, not even an instruction in the box I even contacted qtp directly aswel bit no joy the agent I got it from assures me it's internally regulated I might just try til hook it up and see what happens
/ Ford 4000 alternator #12
On their site I saw a wire harness stub.
/ Ford 4000 alternator #13
Yea I noticed that, I took a chance and wired it up anyway removed old v reg. heavy cable to battery and smaller spade terminal to battery light, fired her up battery light went out and battery Is holding steady at 14v + at idle, seems good to me?
x (A68191)
x (A68191)
2019 CATERPILLAR 315FL CR EXCAVATOR (A65056)
2019 CATERPILLAR...
2007 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2007 Kubota...
2011 DRAGON  4 AXLE CRUDE TRAILER (A67714)
2011 DRAGON 4...
FUEL TANK (A68842)
FUEL TANK (A68842)
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
