Kubota m6800 running hot
/ Kubota m6800 running hot #1
fcoats
Member
Grenada, MS
Kubota 6800
My 2004 Kubota M6800 HDC heat guage shows hot and engine feels hot, but water feels cool in radiator. Radiator coil is clean, and plenty of coolant in radiator. Do you have any suggestions. I tried doing a search, but got no similar hits.
Thanks, Filo
/ Kubota m6800 running hot #2
check fan belt and water pump. maybe check with inferred temp gun
Thanks fan belt seems to be OK. I have thought about a thermostat, but not sure it has one.
/ Kubota m6800 running hot #4
Stuck thermostat and yeah, it's got one.
/ Kubota m6800 running hot #6
Do you have a loss of power? A clogged injector will cause a heat issue from a dry cylinder.
/ Kubota m6800 running hot #7
Thanks I'll check it.
Get one from Kubota and just pay up for it. Don't forget the gasket and drain a gallon of coolant from the radiator before you start. It would also be a great time to flush and change the anti freeze plus check the hoses.
New/Unused Landhonor Power Rake (A65583)
New/Unused...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
New 43X16-20 NHS tire on 6-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 43X16-20 NHS...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
