Buying Advice needing a small tractor with backhoe
/ needing a small tractor with backhoe #1
gravelman
NH
Kubota 2650
Hi folks..gravelman here from chilly NH. i m thinking of buying a small tractor...25 hp with a loader and backhoe. I have a Kubota but would consider John Deere or Mahindra (closeby dealers) Im thinking turf tires, no cab. just wanting to know if anyone out there has an opinion, especially the backhoe part. i would want a thumb on it too.. thanks alot.
/ needing a small tractor with backhoe #2
Why not just buy the backhoe for your 2650? Do you need a separate tractor for a different location, or something like that?
/ needing a small tractor with backhoe #3
It's too bad you don't have a Massey Ferguson dealer nearby. I have a gc1710 and it's a beastly little machine. It's first task was to dig footings for a cabin in rocky soil. It exceeded my expectations. I put a thumb on it just last weekend and promptly went out and picked up a giant rock with it. Always remember you will have more lifting weight capacity on the back end, hence the backhoe and thumb, then you will on the front with the loader.
I think most <25 hp tractors with a backhoe are pretty comparable these days. Plus if you stick to <25 hp tractors, you won't have to deal with all the emissions equipment and added expense.
i have a cab on the 2650, i think that is a drawback Also, wanted something small with turf tires to run on the lawn, work in garden etc. My wife will probably be the main operator and she likes small, like my old Mahindra max 25 i would also look for something used...
i actually do have a Massey dealer fairly close...
/ needing a small tractor with backhoe #6
Iseki in Japan builds them for Massey and they have that Japanese quality about them. Definetly give them a look, they were about $3,000 cheaper than the JD and better quality.
Compare front axle size on the JD and Massey, huge difference. Plus the Massey had the most front loader capacity at 800 lbs, if I remember correctly.
i will do that..thanks much
/ needing a small tractor with backhoe #8
I like LS tractors I have a 10 year old Farmtrac with a montana 7.6 backhoe LS built it, and they use Mitsubishi engines. She is a strong little beast.
ok, i will check that out also..thanks
/ needing a small tractor with backhoe #11
Max26/28 TLB?
that is neat..i will look it over
/ needing a small tractor with backhoe #13
If you are looking at the sub-compact TLB then take a look at the Kubota BX25D. Or if you want a lot more, the Kubota B26TLB. The BX25 will be great for working your yard but I would keep it out of the brush. The B26 is a bit heavy at 4000# but I use mine all the time to work in the yard, just have to keep it off when it is wet or it will leave some tracks. Consider buying used for these two tractor because new prices are a bit hard to take. My B26 new cost as much as my 70HP LS with cab and FEL, but I got a good deal on it for $20,500 with only 68 hours on the clock and like new condition.
thank you for all of t hat... i do have a B2650, i did not get a backhoe as it has a cab on it... this time around i really need the smaller machine and i agree with you...look for used.
/ needing a small tractor with backhoe #15
I second that. I did a lot of research before I bought mine about a year and a half ago. XJ2025 was the biggest bang for the buck. no regrets.
/ needing a small tractor with backhoe #16
I bet it would be real hard to find a $20K Nice B26, but if you do, forget the Mahindra idea.
/ needing a small tractor with backhoe #17
All good recommendations, and you probably can't really go wrong with any known name in that size tractor....they're all good.
The thing I would do after narrowing down the field to a couple is get your wife to run each for a few minutes just to make sure there isn't something that will bother her....peddle arrangement, seat position, etc. It's the kind of machine you're likely to keep indefinitely, so no sense in buying something with a major annoyance factor like a loader control you can't reach comfortably, or similar.
/ needing a small tractor with backhoe #18
Mine is a 2009 that I bought in 2010 as a third owner. I think the first owner sold it just prior to bankruptcy and the next owner used it mostly for mowing. IIRC the new cost in 2010 was about $35K at the Kubota website as mine is equipped (hydraulic thumb and 3PH parts) I suspect, $20K would still be a bargain for a 2009 today.
/ needing a small tractor with backhoe #19
The bx23, 24, 25 I think are all very good in what they do. I am pleased with the bx I have and have on had minor problems such as cv joints and u joints that I replaced or rebuilt. Other than that just regular maintenance.
/ needing a small tractor with backhoe #20
Gravelman,
I am in Maine. I am ordering a Mahindra 1526HST with loader and backhoe. I cannot give recommendations on how it operates but after reading for weeks here on TBN I chose the Mahindra. I wanted something smaller to get around in smaller areas. Seems that Mahindra has some good deals for rebates and such and a local dealer seems to be very attentive. Very important in my book.
2016 Takeuchi TL10V-2 Compact Track Loader Skid Steer (A61567)
2016 Takeuchi...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2014 CATERPILLAR CB34B XW DOUBLE DRUM ROLLER (A62129)
2014 CATERPILLAR...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
40ft Shipping Container (A61166)
40ft Shipping...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63118)
Greenworks...
