JD 445 gas Kawasaki engine fouls the plug on the left cylinder
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #1
BrianQ
Camano Island, WA
John Deere 445 gas
I have replaced the coils, the injectors, switched to a hotter plug, checked the computer module, replaced the temp sensor. Still can't get the left side to run without fouling which causes missing and loss of power. Does anyone have additional suggestions as my JD mechanics has given up on this older rig. I love the machine and wish to keep it going. The service techs contacted the main corporate service center and they said that it was too old for them to put energy into helping them solve my problem. They actually refrained from charging me for the true total of hours that they put into trying to fix it for me. They did get it running better by discovering a problem with a secondary wiring harness that attached to the temperature sensor. It ran reasonably well for the Summer, but in the cool temp it is back to erratic running. What now?
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #2
:welcome: to TBN
Did they do a compression check?
Hard to believe they gave up on you.
How many hours?
What is the serial number?
Yes, they did a comp test. I'll need to check the hours and serial and get back.
The only number on the engine that I found was on the side of the air cleaner: SKA617U5G2RA. Hours 1056, but I suspect that dial may have turned over in past 20 years. I didn't buy it originally, it came down to us from my Father-in Law. He had it serviced regularly. Wish I could give you more input.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #5
How about the serial number of the 445? Is that available? The tractor s/n would be something like M0445D0xxxxx and on the right side of the frame below the engine.
What were the numbers for the compression test?
That s/n plate has been obliterated over time. I checked it when I went down to check for something on the engine.
I would have to check with the JD service staff to ask them if they recorded the comp readings.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #7
Using low ash oil?
Filling to oil level according to the operator's manual?
PVC system slobbering oil into the left cylinder ?
Operating the engine under load at max rpm or putting around ?
Coolant temp 195F with a working stat ?
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #8
is the plug being fouled by oil gas? If oil is is possible one of the valve stem seals is bad. This probably would not show up on a compression test?
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #9
Engine s/n is located on the front of the engine just below the crankshaft stub out the front.
Hopefully the FIL will have an owners manual or other paperwork that has the s/n of the tractor penciled in or on the receipt.
Checking with the original dealer may also be an option. Hopefully it is not the same dealer that wouldn't fix this one (sounds like they wouldn't give you the time of day). Deere keeps records of their tractors, if the dealers cooperate.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #10
Is it gas fouled or oil fouled? Did it burn oil or smoke at all? Like others have said- look for the PCV hose connection and see if that hooks up to the left side intake runner. If so, remove it and see if oil is present in the tube.
Do the two injectors work off the same wires or different wires? If they are different wires, I'd swap them and see if the right cylinder runs rough.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #11
Appears, to me, there is just one injection nozzle. It being to inject fuel into the carb, unlike the diesel injector systems.
I stopped by the JD service center and picked up a copy of the mechanic's notes. Comp Test results 230 PSI for both cylinders. He next removed the left side valve cover to check the push rods and they were fine. He replaced the valve cover O ring.Valve clearance was good at .010. Plugs on both sides were soaked with gas and sooted up. So it appears that the fouling is gas not oil.He replaced the injector nozzle with no improvement in running. He then pulled the manual and ran a 30 point test. Test# 16 indicated the grounds to the module were not grounding like they should. He traced the wires and found a splice that might be the problem. Still had a high reading, so he spliced in 3 separate ground wires to fix the problem and found that it ran better. They then checked the fuel pressure(spec 25-27) actual pressure was 30 PSI. They replaced the fuel filter (which I had already done). They had a new fuel injector module and they tried swapping and it did not make any difference. So they moved to replacing the air pressure sensor as it helps control the fuel. They changed out the fuel pressure regulator and the fuel return line and monitored for any noticeable fuel pump problems. They changed out the coolant temperature sensor as well. At this point the engine was running only marginally better. He turned on the key and disconnected the air temp sensor as the manual had indicated that it could be a source of the problem. Once he reconnected the air temp sensor, he started it back up and it ran great! He replaced that secondary harness to the air temp sensor and it was running pretty darn good when I picked it up. It ran strong with no problems until now. It is back to fouling and running rough.
Appears to be gas fouled.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #15
Wow- that was a real thorough workup by the mechanic. Thanks for posting all of the details.
Does that engine use any type of vacuum operated fuel pressure regulator (like many automobile engines) that increases fuel pressure when vacuum is low? If so, I would investigate that as a possible problem (sticking and making the mixture too rich even when vacuum is low). You said they changed the regulator, but did they put the old one back on?
I would also wonder about the coolant temp sensor and the air temp sensor. You said that they "changed them out"- but did they put your sensors back in after the test? If the coolant temp sensor was relaying info that the engine was very cold- then the computer would richen the mix. Some engine also richen the mix when the engine is running a little too hot. Do you have a temp gauge on the machine? Does it run any smoother when it is cold, lukewarm or full temp?
They replaced the coolant temp sensor and I just replaced the air temp sensor. It runs better in warm temps. There is a coolant temp gauge and it seems to work fine.
I am not certain about the operation of the fuel pressure system (vacuum or otherwise). To me it seems that a lot of fuel is going into the carb. They replaced the fuel regulator.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #17
I am leaning towards an engine with low coolant temp or an engine controller receiving a signal that the coolant temp is low or the airflow is higher than it actually is?
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #18
Like buickanddeere I am also leaning toward an issue with coolant temp. You said the coolant temp gauge works ok. How far does the needle come up on the temp gauge?
I may have missed it, but did you replace the air cleaner or check for a mouse or insect nest/other restriction in the air cleaner housing?
I've replaced the air filter and inspected the housing and intake area; no obvious problems. I'll have to run the motor to see what the temp gauge shows once it warms up.
/ JD 445 gas Kawasaki engine fouls the plug on the left cylinder #20
Did it start running badly all of a sudden in the past few months? Or has it been a gradual process?
If the thermostat is stuck open, or the engine is one the verge of overheating, that could also be the issue.
Does the engine start quickly and run good when cold? It almost sounds as if the engine control unit is keeping the mix rich (as if the engine is cold) even when the engine gets hot and should be running on a leaner mix. Did they unplug your ECU and plug in a replacement? If the coolant temp sensor is working OK, and the wiring is OK and the fuel pressure regulator and injectors are OK, then I would think that swapping in a known good ECU would be the next thing to test.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Ford F-150 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
1995 Chevrolet S10 Pickup Truck, VIN # 1GCDT19W7SK120441 (A61165)
1995 Chevrolet S10...
