dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,618
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I think I know what you want, and I did it once. IIRC, The kubota fuse block feeds power to all the slots on one side, and then there is another socket/terminal on the other side of the blade for active circuits that they actually installed. It either has a contact/socket or is blank on the load side. So you need to come up with a way to make a "blade socket" for the one side, and you can add a circuit easily. It was quite a while ago, so i don't recall the details, but I basically went to a bunch of auto parts stores and places like Fleet Farm/TSC to see what I could find, with a fuse in hand. I finally found something that fit the blade, and then figured out a way to put it into the slot on the fuse block from behind and secure it. I don't recall how exactly i did it, but it was not hard. I think what I used for a contact did not enclose the blade on all sides, but was one sided. Careful bending with needle nose and a small vise made it fit as required. It held up well, and is still in service today (sold the tractor to a coworker a couple-few years back). Wish I recalled all the details as it was a good hack, but I pretty much just winged it and it worked fine. very clean install, and you would not know it unless you went into the back of the fuse block and looked closely.
Now switching it with ignition requires you to tap into an ignition triggered circuit to run a relay. I did that with this one too as it was for the third function for the grapple. Just find a lightly loaded ignition switched circuit and have that feed the coil on a suitably sized 12V relay, and you are in business. Feed from your new fuse circuit to the IN contact on the relay, then feed from the OUT contact to your load or switch.
