Rearview Mirror for inside Grand Cab
/ Rearview Mirror for inside Grand Cab #1
Thirsty
PA
Kubota BX 2230, L5460 FWD, HSTC
I'm looking for a mirror for inside my grand cab on my L5460 HSTC. Anyone have any ideas or sugggestions?
Thanks in advance.
Thirsty
/ Rearview Mirror for inside Grand Cab #2
What about using an automotive rear view mirror? Could get one out of the junk yard. Just remember to grab the metal mounting part that glues to the glass.
Not a bad idea. I'm bouncing between a mirror and a rearview camera. Mirror clearly has price advantage.
/ Rearview Mirror for inside Grand Cab #4
Look on amazon there is a large selection
/ Rearview Mirror for inside Grand Cab #6
They make a wide angle mirror for skid steers that will give you a panorama but they are poor for details.
/ Rearview Mirror for inside Grand Cab #7
Not liking the side mirrors? Or they just not covering what you need?
I just tightened down the screws on my L4060 so they don't point at the ground after 5 minutes. Not enough hours before or after tightening to have a good opinion on my machine.
I didn't end up using the cheap bucket cam on my L3200 much. Debating if I want to go that route again on my new cabbed machine. Mounting a nicer camera up high on the cab should give good coverage of impliments save your neck. I don't think a rear view mirror would be able to get a good line of sight to impliments.
/ Rearview Mirror for inside Grand Cab #8
I put 2 stick on convex mirrors up in the corners of the front glass of my L4060. Not great for a real view to the rear, but they are well within my peripheral vision to see traffic and other stuff behind me. They are about 4" x 6",
I'm looking for a mirror for a couple of reasons.
1) Watch three point implements during hay making.
2) Watch people loading hay wagon. One slip and they are under the wagon wheels.
In both cases, the side mirrors are pretty good. I'm looking to suplement the side mirrors.
Thanks for the suggestions so far. Am I asking too much out of an inside rearview mirror? Should I be looking for a rear view camera?
/ Rearview Mirror for inside Grand Cab #10
Just an FYI,
I use the side mirrors on the cab and a rear view camera. The camera and monitor were under $50 and the monitor is capable to use two cameras so I have a second camera on the front.
Can you PM me the make and model of your camera.
/ Rearview Mirror for inside Grand Cab #12
Thanks, this is what I was looking for. I tried searching before I made this post. I must have done something wrong when I did my search.
Thanks again.
/ Rearview Mirror for inside Grand Cab #14
When doing a search, use the Google custom search at the top right of this page instead of the search listed underneath.
/ Rearview Mirror for inside Grand Cab #15
It would be a REALLY long 3pt impliment to be able to see it from inside the cab with a mirror. Even then you'll pretty much be trying to look through your own head to pull that off. I'm betting the only way to get a good line of sight on the 3pt & impliments without killing your neck is going to be a camera of some sort.
/ Rearview Mirror for inside Grand Cab #16
Amazon.com : Rear View Mirror for Bobcat Skid Steer Heavy Equipment Dozer Tractor John Deer Deere Kubota Ford New Holland Case Volvo Others : Sports & Outdoors
/ Rearview Mirror for inside Grand Cab #17
We have a L4610 cab which is very small, and places are limited for mounting. We customized our own mirrors by cutting our mirrors to size and mounting them in sheet metal frame. Small, maybe 2-1/2"x4" in each outer corner and maybe 3x24 across the center. Because of the small cab, they are fairly close to operator, which makes view clear & larger. We seldom have to turn to look to the rear. but mine are not set to look a long distance to the rear.
We watch the rear of our 7' finish mower & can back up to any object & touch it without HITTING it, or skinning the bark on a tree.
Working with grapple on loader, we can back up to most anything without having to turn around. When working disaster relief, we really concern a lot of people when they see me looking forward while backing up close to something like a car or building. We also use the side mirrors, but we have to move our head more for the side mirrors, than the inside cab mirrors. Only have to move eyeballs for them.
I deceided to go with a rearview camera setup. I've included a couple of pictures of the final install.
I went with a "LCD auto car rearview color monitor with HD resolution 800480 Digital Screen Display support 2 video input For CD DVD Video Player 9inch Touchscreen car monitor" and the following camera: "Tulun Play TPCM078 Waterproof Car Van Jeep Vehicle Car Rear View Camera, 170 Degree Viewing Angle Backup Camera".
While the screen looks like it blocks your view in the picture, all it really blocks is a veiw of the tractor hood. I already know it is orange so no big loss there.
The second picture is one of the camera. It is rather hard to see up there but it works great.
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A65563)
2019 Ford F-550...
2005 Chevy 2500 Pickup Truck (A66408)
2005 Chevy 2500...
Monosem Planters (A64126)
Monosem Planters...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
