John deere 2440 filters and maintenance
   / John deere 2440 filters and maintenance #12
It would appear that the loader control valves are properly plumbed to a T in the scv supply line and returned theough a ported transmission filter cover. Safer to tie those hoses up out of the way.
That looks like a nice solid tractor. Other than the nose piece on the hood, sheet metal looks straight and not rusted out. The 2440 was a real workhorse. You have the optional rack and pinion axles whichgives you more weight in the wheels. The 40 series utility tractors were being sold new when I started working For dealer in 1977. Set up quite a few of them and installed loaders. Your loader has 146 decals, but the lift cylinders appear to be from a 145. Can't tell on the bucket cylinders but they may be right for the 146. It will make a difference in the seal kits if that is what is leaking. You mentioned you didn't have air filters to install. TxJim didn't give you air filter numbers, so I can tell you primary filter is Ar84228 and secondary element is AE31724. It was nice back in those models. Filters interchanged over many models, now it seems every model takes a different filter and even some differences in serial number ranges or what tier emissions engine you have!?!
Dealer said there are 2 different air filters depending on the serial so I was gonna get it then get the air filter.
   / John deere 2440 filters and maintenance #14
jd110
I didn't sell enough air filters for my feeble mind to remember their part numbers unlike the part numbers I do remember. It appears the air cleaner element filter part numbers you listed are good for all 2440's after serial number 272224 which before that SN utilized a single element PN AT20728
Can anyone tell me the purpose of the lever between the shifters? I was guessing the PTO but I found it on the side. Also what's the lever on the left side on the diff? Diff lock?
   / John deere 2440 filters and maintenance #16
jd110
TxJim, You are right. I was thinking all 40 series used the dual element filter and 30 series used the AT20728. Sometimes my mind doesn't recollect as well as it did and I should have verified before posting possibly wrong info.
Loganhorse, the lever between the shifter is pto clutch when you have independent pto. The pto lever on side is a sliding collar that disconnects pto shaft mechanically. It is handy to let pto turn freely when hooking up pto. You should be able to leave that one engaged and turn pto on and off with lever between shifter if it is working properly. The lever at rear axle housing is the diff lock.
Okay, if the middle one isn't working correctly is this a easy fix?
Sorry for all the questions.
   / John deere 2440 filters and maintenance #18
Ease of repairing ind pto control between gear shift levers would depend on what's wrong with it. So will pto shaft turn with power when lever by left foot when sitting in seat is moved forward but lever between GS levers has no control of pto? If so it's possible that hyd ind clutch plates are warped. Does lever when moved between gear shift levers have ""2 distinct detented positions""?
   / John deere 2440 filters and maintenance #19
jd110
I wasn't attempting to actually prove you wrong just merely clarifying info that I located when looking up 40 series air filters. As I age it amazes me some of the unimportant things such as part numbers I can remember & the important items I can't remember such as relatives birthdays & peoples names.
Jim
Yes when the foot lever is engaged it comes on. Never really paid attention to the smaller lever. I'll check shortly.
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
Hydraulic spike driver (A56435)
Hydraulic spike...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2022 Horizon Trailer (A55973)
2022 Horizon...
