Land Plane Advice
/ Land Plane Advice #1
mcgoo
Barrie
Cat 301.8C
I have a B2650 looking at getting a land plane . I'm in Ontario Canada so I looked at a chinese-made Agri Ease 60" land plan and a somewhat locally made MK Martin. Price difference is marginal $1400 for the former and $1600 for the ladder. Both are the same weight. I am leaning for the Canadian made unit for the quality difference and to support local manufacturing. I have about 1200 feet of driveway to maintain and I also need it for an upcoming job to smooth over a gravel driveway after I trench about a thousand feet. Does anyone have any experience with either brand?
MK Martin - Grader Leveler - YouTube
/ Land Plane Advice
Try everything attachment that's what I 'my going to get.
Yeah thanks but by the time I get them imported you're looking at about 50% on top of whatever the American pricing is. Looks like nice stuff though. Are dollar sucks right now.
/ Land Plane Advice #4
I understand money not free today.
/ Land Plane Advice #5
I have a Land Pride GS2584 - works great on my mile long gravel driveway. But, I would imagine you will run into the same $$ exchange rate problem with that. I know many on here have MK Martin snow blowers and speak favorably of their quality. Given the choice - I would go with the MK Martin.
/ Land Plane Advice
Looks like I can get Land Pride through Kubota dealers around here . I will call for a price on Monday. I want to get a 60 inch not a 48-inch. Is that the correct size for my tractor?
/ Land Plane Advice #7
Hmmmm,,,,
I would think,,, you could buy;
A welder
A steel cutting bandsaw
A drill press
and,,
all the steel you need for the landplane,, TOTAL, for less than $1600,,,
Are you interested in doing it yourself? :confused:
/ Land Plane Advice #8
Yep. I built a 72x72 out of used I-beam, 14" tall, and including the cutting edges (I used Titan 4"x1/2" bucket cutting edges, welded to 6x6x3/8 angle), I have less than $500 in it. It's not pretty, but it works great. I'll post some pics next time I'm out at the property.
/ Land Plane Advice
Hmmmm,,,,
A welder
A drill press
and,,
You make a good point... Time is a bit of an issue. I used to be a tool and die maker. Never did very much welding thou.
/ Land Plane Advice
I own an HVAC business now so it a matter of my time may be better served working and paying for it vs taking a few weekends to make it.
/ Land Plane Advice #11
....yeah, but you prolly could "write off" those tools through your business where the land plane? Not sure on how your tax system works up there.
/ Land Plane Advice
I could write it off either way. But it's interesting to think that I would have more tools for the same price that I could use going forward for more builds.
/ Land Plane Advice #13
A 48" would be a better fit for your tractor. I have a 48" that is a strain for my garden tractor but with the extra weight your tractor has this 48" would be a good fit. A 60" would be okay on level ground but would be difficult to pull uphill. You are not going to save time with the 60" vs. the 48" either.
Here is my 48" wide with 60" long skids I built a few years ago. Weighs about 425 lbs and cost about $400 USD to build with 1/2"x6" grader blades.
/ Land Plane Advice
That looks sharp! I am all flat here. I thought you were supposed to cover your tracks with your implement?
/ Land Plane Advice #16
I pull a 60" land plane (deere) behind my JD 1026R (filled tires + FEL) without any issues. I maintain a 1800' gravel drive that only has about 30 feet of flat section along the whole thing, and has one area with a 20deg slope for 100'. I can still pull a full load up that steep section without any issue (4wheel and diff-lock engaged). Frankly, when/if I upgrade to a new 2R series then I'll certainly step up a size (72"). A Kubota B2650 with filled tires would greatly outweigh me and should be able to pull a 60 without much/any effort, and personally I'd try a 72.
Edit: yes, you want to be able to cover your tracks. It's also really nice to have a couple extra inches so you are not riding the edge all the time when your blade is. Same thing with a rear blade. On a B2650 I would load my tires and run a 6' rear blade and/or land plane.
/ Land Plane Advice #17
I would consider having 4x4 AND DIFFERENTIAL LOCK ENGAGED a strain on your tractor. I understand you can pull the 5' with your 1026R but better to size implements to your tractor that are not always straining everything.
On a hard packed driveway the land plane grader scraper is easy to pull. On a soft driveway or after a rain it can be much more difficult to pull and you have less traction too. I like to suggest combinations that will work well in less than optimum conditions.
A 4000 series Deere with ballast will pull an 8' lpgs in most conditions.
A 3000 series Deere with ballast will pull a 6' lpgs in most conditions.
A 2000 series Deere with ballast will pull a 5' lpgs in most conditions.
A 1000 series Deere with ballast will pull a 4' lpgs in most conditions.
The above is my opinion for heavy duty land plane grader scrapers without straining the tractor and use under a variety of soil and moisture conditions, with and without some slope changes.
/ Land Plane Advice #18
Thanks for the compliment. Covering your tracks is optimum but not necessary for using a lpgs on a driveway. For box blade work you need to be wider than your tires so that you can dig deeper. The first time you drive anything on the driveway it will make tracks until packed down so I would not worry about the lpgs width in this case.
Weight per foot of width is important and structural strength that keeps everything rigid without flexing is key to a good lpgs, Long skids and plenty of weight allows for a more aggressive cut when needed and a smoother less undulating roadway.
/ Land Plane Advice #19
Hmmmm,,,,
A welder
A drill press
and,,
There is something quite satisfying about learning something new. In this case, look at all the money learning the basics of welding will save you in the future.
/ Land Plane Advice #20
I want to build one. Just not sure I have the need for it to justify the build. I have most of the material already. I think it would be a simple build. I'm more about productivity than cosmetics too. :)
Location Tampa, FL (A61567)
Location Tampa, FL...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
