Working tire pressure = Contact area ???
/ Working tire pressure = Contact area ??? #1
rdinatal
Gold Member
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
I was wondering what the thoughts are on tire pressure. It doesn't matter if they are filled, or not, or tractor weight. I'm interested about contact area. I was thinking of 80% contact on a hard surface like cement. At any time in the work day the supported weight can be plus or minus 1K lbs depending upon a laod in the FEL or 3pt. On mine at 80% contact, unloaded, the rear would be at 10psi. That seems low.
On my truck I like 90% contact to the shoulder but then the truck doesn't have as much of a weight variance in everyday use. When I want to load it I air up/down accordingly.
So, on a tractor what do you find is a good balance between ride and capacity??
-R
/ Working tire pressure = Contact area ??? #2
I run all of my tractors at max psi that is printed on the sidewall. Especially important for the front tires of a loader tractor. They never gave me a smooth ride no matter how much air they have.
/ Working tire pressure = Contact area ??? #3
Ditto for me.
/ Working tire pressure = Contact area ??? #4
I run my fronts at max psi. I run my rears so I get full ground contact.
/ Working tire pressure = Contact area ??? #5
I run mine at 45-50 psi. I think max rated pressure on mine is 45.
/ Working tire pressure = Contact area ??? #6
My loaded R4 rears I run at 15 psi, fronts at 35
/ Working tire pressure = Contact area ??? #7
Loaded rears at 18psi, fronts 20psi, up to 24 for FEL work and back down again for traction/ride comfort. Ag tires.
If you do much on pavement go 2psi lower, over inflation wears the tires out faster than under inflation as the circumference from center to sidewall has a greater difference with more pressure
/ Working tire pressure = Contact area ??? #8
It kinda depends on the type of tire and the service it is in.
/ Working tire pressure = Contact area ??? #9
10 PSI in the rears is about right for good ground contact. I would never run the rears OR fronts at or above the max rating. I only run enough pressure in the fronts so that they don't squat or roll on the rim when I have a fully loaded bucket. This is usually 10 pounds or so below max pressure.
My eMax is about 2200lbs with the loader. The dealer had the rears at 15lbs and I was noticing the contact was about 60%. With 10psi the contact increases to 80%. I really don't want to go any lower.
I need to check the front.
-R
So I had another job to level a 12'x20' area for a greenhouse. The night before I put the front tires to the max psi and made sure the rear were at 80% contact (10 psi).
Very happy with how it performed. Plus the flotation of the rear while using the subsoiler to breakup the Carolina Cement was better. Not sure on the load of the FEL as it was mostly take 2" from here and put it there. I feel I'm covered.
Thanks for all the input. There were some items that I never thought of.
-R
/ Working tire pressure = Contact area ??? #12
I run my front tires at max pressure - 40 psi - as I remember, because my grapple in on the FEL at least 95% of the time. I run the rears so I get 100% ground contact with the tread bars. I think the rears are around 16-18 psi. I run R-1's - front & rear.
However - take these pressures for what they are...... my M6040 weighs 9866#. It has an 820# grapple - 1455# rimguard loaded rear tires & 566# rear blade. Soon it will weigh 10,265# because I just bought a new rear blade that weighs 965#.
/ Working tire pressure = Contact area ??? #13
If a tractor has mechanical 4WD then just as important as pressure is pressure ratio because a pressure caused radius imbalance will strain the transmission and drive shaft(s) because of the mismatched Front to rear drive forces. Tire wear is usually the immediate penalty, but as the grip level rises, the internal drive train strain does too. You can tell when a problem arises when it becomes difficult to disengage the 4WD.
/ Working tire pressure = Contact area ??? #14
The subject of this made me think of something that's useful to keep in the back of your mind... The OP titled it "Working tire pressure = Contact area ???"
I know after reading what he was asking, but I'll add some other useful info, as I deal often with maximizing vehicular mobility in general over rough terrain...
On ANY tire, you can equate tire pressure to ground contact pressure, as long as you're on a semi-hard surface. So if you have 80psi in your truck tires, the tire is touching the road with roughly 80psi of contact force. (averaged over the entire contact patch.) If the surface is softer, and cannot support a contact pressure corresponding to tire pressure, the surface will deform until it has achieved a lower contact pressure by increasing the contact area. Any time surface deformation needs to happen, traction suffers. A good example of this is wheel hop in softer conditions... Wheel hop is the result of the surface not being able to hold the contact pressure, and deforming to achieve a contact pressure that can be supported. You'll find that as you lower tire pressure, the surface will need to deform less, and wheel hop is reduced. If you lower pressure enough, wheel hop will be virtually eliminated, and you'll notice that your tracks don't appear to deform the surface much at all.
(climbing onto my soap box...) For CUT tractors, which often do much more loader work than "ground engaging" work, I find that tire sizing is completely wrong... We really need larger tires on the front to carry the weight better. With ground engaging work, like plowing or discing, the 3pt pulls down, weighting the rear tires and de-weighting the fronts, so small front tires are fine. Since typically, that's what tractors did, it became the norm. But with increased loader work, and decreased amounts of ground engaging work that most CUT's perform, it makes no sense to have small front tires... For the scenario common to most CUT users, similar size tires front and rear would make much more sense. I realize that turning angle would be obviously limited as the front tires get too large, but but most CUT's could easily have been designed with front tires several sizes larger, and at least closer in size to the rears, which could often be smaller and would still work fine.
The worst example of this that I can think of is the LS 3xxx series tractor. I referred to it as the "T-rex" of tractors when I was looking. The rear tires are HUGE compared to the tiny front tires. Why?? No good reason, I assure you. Search for stuck pics of this model, and you'll almost always see the front buried. Tires too small for the load they're subjected to on soft surfaces. This is an odd contrast to the 4xxx series, which has much larger front tires relative to the size of the rears.
Running either end at full pressure all the time is akin to running all four of your truck tires at full pressure. Tire wear suffers, traction suffers, surface damage suffers, ride suffers, and they become much easier targets for punctures. There is NO REASON you should be doing this on ANY tractor.
OK, I'll climb down. Please use tire pressure to your advantage. You'll find much improved traction, and mobility, and you'll ease the work for your tractor as well, particularly in soft conditions. Meanwhile, I'll continue to watch for a more reasonably designed CUT to come out. :)
Oh, and rest assured that tire pressure does not significantly change the revolutions per mile of any tire. You can run the front's nearly flat, and the rears at max pressure, and not affect the drive ratio by enough to even notice. It has to do with the fact that the same amount of "belted" rubber has to contact the ground. You'll find people saying differently, but in the tire industry, those people are called "the uninformed".
I wish you all success in your quest for better mobility!!
/ Working tire pressure = Contact area ??? #15
I believe Duece is correct... and not just because he's living in my hometown -neck of the woods-.
Higher pressures result in more compaction. One thing many here don't think about, is that, typically, we 'mow' in a very consistent pattern. ie, we put the edge of the mower right up along the fence, road, driveway, etc and begin mowing. We move in a mower width each pass. Our tires go over the same ground again and again, many times a year. This might not seem like much, however, this repeated driving compacts the ground and can result in significant subsoil compaction. Doing this with high pressure tires increases the degree of compaction significantly.
"Tractor experts agree there is no single, simpler way to improve tractor efficiency than to use the proper tire inflation pressure (6). Proper tire inflation not only improves tractor efficiency but can reduce the intensity of the compaction from the tires. The table below lists the proper tire inflation per axle load and tire size. When duals or triples are added to a tractor it reduces the carrying load on each tire, thereby reducing the necessary tire inflation rate. This also decreases the depth and intensity of the compaction."
Tires, traction and compaction : Soil management and health : University of Minnesota Extension
/ Working tire pressure = Contact area ??? #16
For R-1's the rule of thumb is that three bars on the tire should be flat on the ground. That's a lot lower air pressure than what others would think. Ag tires aren't like car tires with more air pressure better than less. Higher pressure causes more compaction plus doesn't let the tire contact the ground sufficiently to utilize the R-1 tire.
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
John Deere 50 (A60462)
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
