Drill seeder help
/ Drill seeder help #41
Most years we get a wet spring that's why we get one good cut. After that the only thing that will grow is weeds. :confused3:
I guess they don't need water.:confused2:
Weeds never need much..
I will do some research and pondering on this.
What sort of weeds are the problem, imagine they have deep roots.. you could try plantain/chicory/red clover maybe. That's why I'm looking at chicory, nice deep roots to make the deep minerals available, and rob the Cali thistles of nutrients and moisture. Although my aerway style machine gives them something to think about!! Apologies for going off topic
/ Drill seeder help #42
All model B drills had galvanised seed box
Thank you Jim for the clarification. My dad sold Allis Chalmers for over 25 years from 59-84. He and my grandfather had 2 small cattle farms. We used the B for years on oats, soybeans, wheat, etc. I remember standing on the rear floor board while dad drilled the crop in checking to make sure all the openers were working properly. Good old days and great memories. Lots of old B's still for sale and in use. Those with the small seed box have pretty high resale prices.
/ Drill seeder help
When I was looking for a drill, I found lots of junk that I wondered if it would work at all. I really wanted the small seed box but the drill I got was in such good shape I couldn't pass on it. But, yes those with the small box in good working order can ask whatever they want for them. If you don't buy it, the next guy will.
/ Drill seeder help #44
That seems super risky with alfalfa because the grain has bigger seeding gears so even if you taped the hole smaller and put in a smaller seeding rate, it would very difficult to measure the lbs/acre. On top of that the alfalfa will get drilled into the ground so it'll probably get buried a few inches underground. My dad has a newer drill with tubes for the alfalfa, they're supposed to go down right behind the drill but he put the tubes in the drill, they seeded a few inches underground, and then only a small amount of the alfalfa grew and he harvested about a ton/acre for the whole season instead of 4-5 and didn't know why. Once I pointed that out he learned his lesson. The grain and hay boxes are different for a reason.
Not sure how many acres you're seeding but I'd probably pay the neighbor to seed your field for you.
/ Drill seeder help
From talk here on TBN I've decided to not even try planting alfalfa with my seeder. I appreciate all the feedback.
I am looking forward to planting in the next week or so with the mix I mentioned earlier.
/ Drill seeder help #46
I have a John Deere Van Brunt drill seeder. As you can see from the picture it does not have the small seed box.
Here's my question; could I duct tape the seed outlet mostly closed and then seed with alfalfa? In my head it would work but I'm not sure it would in the field. :laughing:
Hopefully TXJim see's this post and replies.:thumbsup:
I have that exact drill and yes there is a chart under the right hand lid. I setup all my equipment to run on 6' widths so I blocked off the ends to get the 6' dimension. I used thin sheet metal from a piece of junk lying around and held it in place with RTV. Has worked fine for many years. On partially blocking off a hole from inside the hopper, I don't know if that would work for you or not. I have repaired worn places on mine, from the underside with the same thin material....soda pr beer can works great, and RTV so that I could use the minimum settings.
/ Drill seeder help #47
I got new springs for mine off ebay. Also JD still stocks some of the parts, for example, the spring inside the drop mechanism to name one, chain and sprocket for one drive also, I think they had springs too but needing 12 (as I recall for my reduced 6' drilling width) was priced over what I wanted to pay.
/ Drill seeder help
The weather has been warm and dry for several days now. Fertilizer was put on Friday. I was able to get my field and another field across the street from me ready for seeding. Plan to get that done on Monday.
/ Drill seeder help #49
I like that field cultivator and harrow . Much nicer job than a disc .Wow , what a view !
/ Drill seeder help #50
Don't know how he gets anything done. I'd be gazing out the cab window at the mountains and run thru the fence.....
/ Drill seeder help
Trust me, sometimes the lines are not very straight.:laughing:
Kevin, it only looks nice from a distance. The spring tooth is really nice but the drag behind it is only some old rod iron railing with some weights added on. It does an OK job getting everything smooth, but at some point I'd like to get something better.
/ Drill seeder help #52
I made a drag out of an extra heavy duty cattle panel. Added some old truck tires for weight and still have flexibility. It works okay unless working around a lot of debris, tends to plug up and start dragging a pile. But the price is right. :)
/ Drill seeder help
That's why I have the one I have, "the price was right".
Here is the beauty.
/ Drill seeder help #54
Just like the kind you buy!!!! :)
/ Drill seeder help
Last night after work I seeded a neighbor's field. This is the first time I have used the seeder. It seemed to me it is set to low. I found a couple tubes clogged up with hornet nests. Overall it worked fine, but I need to raise the seeding level. It seemed to clog up a little going slow. I sped up some and no more clogging.
So, at this point I'm very happy with the seeder.:thumbsup:
I will be seeding my own fields tomorrow, glad I got all the cobwebs cleaned out. (hornet nests)
/ Drill seeder help
So I was able to seed 11 acres yesterday. Everything worked fine, but I do need to make some adjustments to the drilling depth. Now it's time to pray for rain. Weather man says some storms are coming next week. Sure hope he is right.
/ Drill seeder help #57
My word that is beautiful country. You will like your drill. Those are great units. When we drilled I was always stationed at the back riding the rear running board to make sure all spouts were open and working properly. Great memories.
/ Drill seeder help #58
Thanks for the pics. Makes me feel good just looking at them. :)
/ Drill seeder help
Thanks to the both of you.
I was able to figure out how to raise the drill depth today. Should not have to touch it again. Back to hoping for rain.:thumbsup:
Can't resist posting one sledding picture. This was taken about a week ago.
/ Drill seeder help #60
I love your playground!!!! Soooo many people live near great outdoor playgrounds and never utilize them.
Sledding keeps your body/mind young. I 4 wheel with my family and a group of friends to do the same thing.
Great picture!!!!
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
HONDA generator (A64553)
HONDA generator...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
