Man lift for fel
/ Man lift for fel #91
:thumbsup: Thanks for the update.
/ Man lift for fel #92
For anyone that followed this thread or interested......winter and other projects got in the way, but I finally replaced the rope on the flagpole using this setup. It's was a cake walk. Did not feel unsecure at all. In fact I've been in far more tree stands that was less stable than this was. I had a neighbor very experience with tractors to do the left etc. It really turned out to be quite easy.
You would give a safety man a stroke if you did that on a job site! Be walking to the gate.
/ Man lift for fel #93
Lol. No doubt
At home we get away with things we wouldn't at work.....
Until we don't.......
/ Man lift for fel
I know....I know.....BUT like I said, I've sat for several hours in tree stands that was far less stable. I had the parts bin strapped solid to the forks, and the ladder to the parts bin....it was solid. I was a bit surprised how stable and easy it was to do.
/ Man lift for fel #95
Yea.....
I would probably do it too, just never document and set yourself up to have the world of TBN lambast you now for actual and perceived safety violations
Lol
/ Man lift for fel #96
How long have you got before the safety police are back!!!
I climbed 50' up a tree last month with a big saw and cut the dead top out, I wish I had a lift like that already. I won't post what I used to get the first 30' now I have 30 trees to top at about 25-30' so...
What changes would you make if you had to hypothetically do it again?
Not to be used, of course..
Thanks,
Pete
/ Man lift for fel
Thanks,
Pete
I started out to weld together a box of sorts to put on pallet forks then came across this parts bin. For my purpose wouldn't change anything/ The parts bin near perfect for the task. If I needed to go higher, just tilting the ladder so it's near vertical, I think, would put your weight directly on the ladder, and in so doing believe I could have extended the ladder a fair amount more. It was not different in going up the ladder if it had been leaning against the house.
/ Man lift for fel #98
I used to get the job of climbing 120' of tower with an adjustable crescent in my pocket as a kid so I believe in holding on .
I was planning on hanging an alloy ladder off the side, on hooks. I'll be by myself most of the time and it's the only way I can think of to get in and out without shinnying the FEL all the time, can just climb down and unhook to move and then go back up.
I have a couple of tree lines than really bug me as I have to hug the side of the laneway too much in the tractor to save my mirrors etc. Plus some big leaners that pose a bit of a problem that I need to top., I really like the thought that's gone into yours. Luckily I have a decent sized ag tractor so I'm thinking about 9 foot wide will be what I aim for.. will let me get a little more done at a time. May put a bracket for a little saw vise for giving the saw a rub.
I plan for mine to double as a carry tray/calf carrier so will have to make the side rails close together with an in-swinging gate and a removable front for utility use. That will hopefully mollify any safety police that see it and ask..
Thanks for posting as I wouldn't have found your thread otherwise!
/ Man lift for fel #100
Personally, I may have secured the ladder differently in the basket but a man cage on a heavy duty loader is what it is. The "safety" police sometimes turn out to be the same guys with the $400/hr ladder truck that "you should use...". And that's before the trip charge!
Great fix!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2025 Kubota KX040-5 (A60462)
2025 Kubota...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
