NX series Power Beyond Port
   / NX series Power Beyond Port #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Does the NX series tractors have a Power Beyond Port, if so, where? I am considering installing a valve for a grapple bucket setup + plow pistons. TIA for any help. I know Kioti sells a kit for $1250.00.
   / NX series Power Beyond Port #2
Yes it does, it's on the back of the loader valve , I believe it's the same on a open station as the cab version. It is the line with the banjo bolt fittings that runs from the loader valve to the rear of the tractor were the rear remotes are located. You'll have to have adapters to replace the banjo bolts with so you can new hoses to your new valve.
Thanks for the information. I will check that out once the snow stops flying around here. It is a "next summer project" for me to add the forward hydraulics on my tractor's loader for a grapple or possible angle snow plow setup.
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
6' ROTARY MOWER (A57192)
6' ROTARY MOWER...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
66'' root grapple (A53421)
66'' root grapple...
Cushman Electric Utility Cart (A55851)
Cushman Electric...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
