Bucket bleed down?
/ Bucket bleed down? #44
Cabin fever sets in again .
Yep. For the past couple months I can get out for a day or two, then the weather drives me back into the shop. Today it's 18 degrees, stiff NW wind, 1" of snow on the ground and still spitting. :(
/ Bucket bleed down? #45
If my barn had rollup doors rather than two 17' x 14' sliding doors I would insulate the thing and have a place to work for at least part of the winter. I have run out of things to do. Can we stretch this bucket bleed down conversation any longer? My buckets are still up.
/ Bucket bleed down? #46
You Sir, are an abnormality, that's all there is to it.......
I sympathize with your situation of not having an all-weather shop...... I'd be more crazy than I already am without mine..... :)
/ Bucket bleed down? #48
To leave your bucket in the air will cost you dearly oneday . For all safety let it go down when unattended !
/ Bucket bleed down? #51
winter has been pretty nice around here. Maybe 2in snow total for the year. High temps anywhere from 50f to 70f. Almost no shop time, wife has me remodeling the house. Knee has had me climbing ladders one day and recovering for the next two. Many hours watching netflix, surfing the net and making stupid posts on internet forums. Trying to learn to play a banjo, not much luck. Not much for me to do but watch paint dry.
/ Bucket bleed down? #52
When I took her out two weeks ago, I attempted to dig up my Septic Tank covers. I say attempted because the ground has 6" of frost. Plus the outside temp was in single numbers. All I did was bounce around for five minutes and then put the machine away. I ended up using a bar by hand for six hours. Do you think the Pressure relief valve is messed up? All I did was claw at the ground for about five minutes. The only thing I accomplished was sliding the tractor around in the snow.
You need a ripper tooth!
/ Bucket bleed down? #53
I'm not very good at idly killing time either...... But hey, you are "banking" some points with the wife!!! :D
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
LOT OF METAL GATES (A63291)
LOT OF METAL GATES...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
