Kubota front fenders
   / Kubota front fenders #21
Since no one has responded, let me just say one word: "Messicks". They should be able to tell you the answer, if anybody can.
   / Kubota front fenders #22
Reviving another old thread..... Does anyone know if the Kubota L series "factory" front fender can be ordered from a Canadian dealer? (I am in the US).
Yes you can order from a Canadian dealer IF they are interested in shipping them to you. Some are, some aren't for various reasons. Keep in mind that the fender kit comes will all brackets, fenders and hardware and it is an expensive kit but it's a very well designed kit with very heavy duty hardware. If memory serves me right it's around the $800. CDN range and also remember that they don't fit the L3240. It's has a different front axle. US dealers won't even have a listing for such a kit.
   / Kubota front fenders #23
BUMP. Can someone with a Canadian Kubota Grand L confirm that the stock fenders are mounted using the same hub bolts as shown in the photos on post #12 in this thread? Or if not, how do they mount?
   / Kubota front fenders #24
Not even close to the factory mounted Grand L fenders. The ones on mine are very heavy duty and bolts to various areas around the axel. Keep in mind I'm refering to a 40 series tractor. The 60 series got an awful front fender set up in my opinion. If It's the 40 series your talking about I'll see if I can find photo's I took of them.
   / Kubota front fenders #25
What I really want to learn is exactly how the Canadian Kubota fender mounts to the axle so that I can see what (if any) mods would be needed to mount a set to a L5740HSTC that was made for USA.
   / Kubota front fenders #26
Well that shouldn't be a problem. Those fenders will fit all Grand L's except the 3240. I have a 5740 with the factory fenders. I'll look for those photo's shortly.
   / Kubota front fenders #28
Very good pics Paul. Simple idea where they bolt to the tractor.
   / Kubota front fenders #29
This is the only ones I could find looking through hundreds of my photos.
Flickr
Flickr
Flickr
Flickr
Thanks for those photos! That's exactly what I wanted to see. Looks like there is enough clearance for tire chains too, all I need (besides the cash) is someone to import the kit.
   / Kubota front fenders #30
Thanks. They are well built and very strong. Not cheap though.
Welcome. Wish I could find one with the wheel off. If your in no rush the next tine I bring the tractor in the shop I can pull the wheel and snap a photo. Yes there's room for chains. Just trim the lower bolts under the plastic portion of the fender. Incidentally your USA 5740's Axel is the same as the Canadian model. The only difference with the Canadian version of the 5740 is higher output alternator, rear cab lights, rear wiper and rear defrost on three windows are standard equipment on the unit and are not considered an option.
   / Kubota front fenders #31
It will probably be a while before I order, so please do post a photo if you have time. Not a big deal if you don't. The stack of brackets on yours is impressive, looks like the intention was to totally avoid anything that could get pushed into a tire, etc.
   / Kubota front fenders #32
Will do. I usually build my own stuff like this but was more than impressed with its quality and I'm happy I bought them.
   / Kubota front fenders #33
Yeah, I started to ask if you had built them, then reread your post. I thought they were too well thought out to be factory. :)
   / Kubota front fenders #34
FatTire- I inquired about ordering a set of Canadian L5740 front fenders a few months back. If I recall correctly, there was a small cost savings if you had the Canadian dealer freight them to your local US dealer. I think it had something to do with NAFTA, allowing a certain fee to be avoided. You may want to look into that if you do order a set.
Also, I spoke with a particular Canadian dealer that was very helpful on this topic. Unfortunately I can't remember their name or find the email at this particular moment!
Paul- if there is any way that I can talk you into fabricating an air ride conversion seat base bracket for the L5740, I would be really interested!
   / Kubota front fenders #35
Usually what's done is the owner removes his seat then the seat pan under it, sends the pan to me and I do the mods needed. Usually one day turn around on my end. If you were in Canada it would be easy but being in the USA causes many headaches sending stuff across the border. I did one for a friend of mine a few years ago. Sent it out to him and then a few weeks later I got hit with a brokerage fee of $70. He was good enough to pay it but it's not a good thing to have happen. Trump complains about free trade. He should be living on the Canadian side if he wants to experance the $hitty end of the free trade agreement. Maybe a local guy in your area can do it!
   / Kubota front fenders #36
Please let me know if you come across the name of that Canadian dealer. I checked with Messick's parts department, the fenders are not in the USA system, and the USA dealers cannot tap into the Canadian system, so I need to start with a Canadian dealer.
   / Kubota front fenders #37
It a old post just wondering if you still have some measurement you can share thickness of steel also the lenght of each peace if you have them thanks
   / Kubota front fenders #39
well that was a fun to do came out ok
   / Kubota front fenders #40
You may want to consider running some supports to the top bearing bolts. Any small amount of flex will allow them to fatigue and crack very quickly. even though I can stand on mine at 200lbs, i still had to repair a few small cracks after 4 years of commercial use.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
Zero Turn Mower (A59231)
Zero Turn Mower...
2019 CATERPILLAR 930M WHEEL LOADER (A60429)
2019 CATERPILLAR...
(APPROX. 20) 4' X...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
