seal leak
/ seal leak #1
rkidd
jefferson ohio
Kubota B2650
Had this posted in the JD section for a while with no luck. Hopefully here I will have more luck as I have had no replies from the green guys. A friend of mine has a JD 4115 HST with 800 hrs. I am an orange guy so not familiar with his tractor. The shaft that comes out of the trans on the right side that runs the HST keeps leaking. There are 2 O rings, an inner and outer on the shaft which he has replaced multiple times with no luck. It starts to leak shortly after replacement. The shaft coming out has no imperfections but there is some play where the shaft comes through in what I am assuming is a bushing. It doesnt look like you could replace the bushing without splitting the tractor. Any thoughts on this would be appreciated.
Thanks.
/ seal leak #2
It sounds like the play in the shaft is an indication of a internal problem. Looks like your friend is going to need to split it to find out why there is enough play in the shaft to cause the leak.
/ seal leak
I finally did find a parts blow up of the shaft. There is a bushing that the shaft goes through. Think it is possible that the bushing is just wore?
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
Parker Gravity Wagon (A66285)
Parker Gravity...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
