Ford 3000 Muffler
/ Ford 3000 Muffler #1
gk527
Member
Kentucky
1974 Ford 3000 diesel / 2017 Kubota B2650
We have a 1974 Ford 3000 diesel that has a bent muffler. Got too close to the trees and it bent the muffler down some. The pipe going in to the manifold is still straight, it's just bent at the muffler. I got a new one for it the other day, but I cannot get the old one off. There's an exhaust clamp on it where it slides in, I was able to get that off. But it won't move at all. Anyone have any tricks or tips?
Thanks!
/ Ford 3000 Muffler #3
Yep, cut it off. Bummer.
/ Ford 3000 Muffler #4
The best way I found for that situation is to use a small air cutter with a 3" wheel. Slice along the muffler as far as it is on the pipe, and it should pull right off. The tricky part is not cutting so deep that you damage the pipe underneath.
/ Ford 3000 Muffler
Would a Dremel work with a small cutting wheel? It's kinda tight in there.
/ Ford 3000 Muffler #7
Yep, hacksaw the muffle off.
/ Ford 3000 Muffler #8
I am going through the same problem on my 4000 right now. There is an adapter that fits down into the exhaust manifold and the muffler goes on the adapter. The adapter is a tight fit into the manifold. After almost 50 years, the adapter has rusted into the manifold and is hopelessly stuck. Rather than fight it, I just went ahead and bought a new manifold for $45. The adapter was $15. Of course one of the bolt heads rounded off so then I had to get bolt extractors too.
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
3147 (A63117)
3147 (A63117)
2025 SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A66734)
2025 SZYMJ...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
2022 BOBCAT T870 SKID STEER (A65056)
2022 BOBCAT T870...
