Bolt with "10" on the head
/ Bolt with "10" on the head #1
POC
Gold Member
Southern Indiana
Mahindra 3215 4x4
I need to replace some broken bolts on my tractor's front axle. They have a 10 on the head, not sure what that means. Any ideas?
/ Bolt with "10" on the head #2
Common to see metric bolts with numerical markings. What I pay more attention to is the grade of the bolt in hardness.
Curious why you have broken bolts?
You might want to visit with your dealer parts department concerning these bolts so you get the right grade.
Dealer went belly up a year after I bought the tractor.
There are 6 bolts, usually. Currently only 3. I guess some worked their way out? And others couldn't handle the strain.
There are no hardness markings that I can see.
Thanks.
/ Bolt with "10" on the head #6
This is probably a Japanese bolt marking
/ Bolt with "10" on the head #9
Not knowing specifically the bolt's purpose, I'll go out on a limb and recommend Grade 8. Might take one with you to the store so you get the correct size and thread pitch.
That was my plan.
It holds the "down angled part" that the front wheel attaches to, to the main axle.
/ Bolt with "10" on the head #11
It's an alien bolt from somewhere around Jupiter.
IO
Bruce
/ Bolt with "10" on the head #13
That was my plan.
Oh yeah, definitely Grade 8.
Might be an area you will have to check often to make sure they don't back out again.
Or not knowing how many hours are on your machine, maybe they were never properly tightened??
/ Bolt with "10" on the head #14
/ Bolt with "10" on the head #16
And there is no such beast as a metric grade 8
Called it whatever you like. So since you know there isn't what do they call a hardened metric bolt? I believe that's what he needs. Enlighten us.
/ Bolt with "10" on the head #17
/ Bolt with "10" on the head #19
I found this showing equivalents:
US Grade 2 = approx metric property class 5.8
US Grade 5 = approx metric property class 8.8
US Grade 8= approx metric property class 10.9
Bruce
/ Bolt with "10" on the head #20
But the Japanese have their own system, there are no pure 10 in std metric markings.
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
1062 (A63291)
1062 (A63291)
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
Adams 8 Ton Blender (A63689)
Adams 8 Ton...
2006 MACK VISION (A65643)
2006 MACK VISION...
