Bobbed Deuce
/ Bobbed Deuce #21
Wouldn't 5th be a road gear that you used after you really got rolling? 4th is where you spent most of your road time and when you went into 5th it was a conscience choice at higher speeds? If so, the shift up would feel natural and like it was by design rather than accident. An "overdrive" kind of shift. I could be wrong because I never had one, but I recall similar setups that I think were made that way on purpose.
The split between 4th and 5th on a Deuce is very wide. While the shift back and forth between 4th and 5th might meet your description. The shift from 3rd to 4th or 4th to 3rd is extremely unnatural. :(
/ Bobbed Deuce #22
I bought a deuce several years ago when they were still available from government auctions - maybe they still are, I haven't looked lately.
I got mine from a guy that was buying three at a time from the Redstone Arsenal sales (I think). He would buy them, fix whatever minor problems they had, and flip them for a little profit.
When I went to look at mine, he had it and one that he had bobbed. I drove both, but since I wanted to be able to haul more material in my bed, I decided to go with the 6 wheel version.
I added a dump bed to it and have used it many, many time hauling stuff around the farm.
It is relatively crude and slow, but I haven't gotten it stuck yet.
I think they hold the re-sale pretty good. I've been offered far more than I've paid for mine, I just have no interest in selling it yet.
Good luck and take care.
Neighbor farmer near me has one with an auger box on it to haul grain out of the field. He's since died. It's sitting in his machine shed. Probably hasn't moved in 15 years. Worked great during wet harvest times. No stuck there. :)
/ Bobbed Deuce #23
There's videos on youtube of someone driving a 5x4 with one of these...talk about unnatural.
/ Bobbed Deuce #24
I've owned 2. They work very well with a closer gear ratio between 9th and 10th than possible the other way. Just takes a bit of getting used to. :)
/ Bobbed Deuce #25
I agree. Its just wrong! :laughing:
/ Bobbed Deuce #27
That a great and classic piece of gear. You should restore it. I would. Doesn't look to have much rust but looks can be deceiving. Especially in your neck of the woods if it's spent any amount of time on public roads. I don't think I've seen as many rust buckets as there are in MI. Only place I know where people have seasonal cars.
/ Bobbed Deuce #28
Here's my favorite deuce and half.
I got to fire one once and it was a real blast. Nothing like the firepower a 20mm Vulcan puts down but it was still a real kick.
/ Bobbed Deuce #29
just buy a "new" unimog. same machine but with front/rear pto and configurable 3pt hitch front/rear so you can actuall do "tractor" work with it
This one is on local CL right now.
/ Bobbed Deuce #30
I do plan to restore it.
Mostly stock, with some improvements.
It isn't too bad rust wise, but it was driven by brail. It spent most of it's life as a plow and woods truck in the south-western part of the U.P. Not sure about road time, but in the 40s and 50s I'm sure they didn't use the amount of salt we do now.
/ Bobbed Deuce #31
Not even close to the same machine. :)
/ Bobbed Deuce #32
Here's my favorite deuce and half. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=497357"/> I got to fire one once and it was a real blast. Nothing like the firepower a 20mm Vulcan puts down but it was still a real kick.
Aren't the tandems 5 tons?
/ Bobbed Deuce #34
A Unimog is whole nother kettle of fish.
/ Bobbed Deuce #35
I think some were but some were deuce and a halfs. My outfit had a bunch of em and we all called them deuce and a halfs including the motor pool folks. Pretty sold trucks as I recall and they'd run on just about any flammable liquid you could put in the tank diesel, jet fuel, gas. Not hard to drive either. Unlike the M108s I had which liked to roll with those swing axles under them and all that weight up top. I had two of em and didn't like driving them on or off road. MRC108-08.jpg I don't know how those stinkin things ever made in into service because they were so dangerous to drive. Can you say unsafe at any speed?
/ Bobbed Deuce #36
LOT of difference between a 2 1/2T and a 5T. Parked side by side it's very noticeable.
/ Bobbed Deuce #37
Some folks called them a 6X6 as well. I never asked, I just drove the thing when and where I was told to.
/ Bobbed Deuce #38
Unlike the M108s I had which liked to roll with those swing axles under them and all that weight up top. I had two of em and didn't like driving them on or off road. View attachment 497377 I don't know how those stinkin things ever made in into service because they were so dangerous to drive. Can you say unsafe at any speed?
Isn't that a M151? I drove those. I thought they were great fun, like little sports cars. It was fun squealing the tires shifting down. I never tried hard cornering though.
/ Bobbed Deuce #39
Yep, made by Ford.
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
New/Unused 20 Ton Hydraulic Jack (A65583)
New/Unused 20 Ton...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A65563)
2004 MCI D4500...
