Good morning!!!!
   / Good morning!!!! #54,601
I gonna jerk a mole out of the ground, turn him loose, if the cat doesn't catch him, early spring, if the cat catches him he won't see his shadow anymore, either way I'm rid of the mole.
   / Good morning!!!! #54,602
63°F and no rain since midnight
Be safe
Have a great day
   / Good morning!!!! #54,603
Good Morning! 47F @ 8:30AM. Partly cloudy skies this morning will become overcast during the afternoon. High 57F. Winds light and variable.
Back on the radiator fan shroud today, cutting the large holes for the fans and shooting a coat of paint.
Bury the conduit I dug up earlier if there's any daylight left...
   / Good morning!!!! #54,604
I like your plan, probably just as reliable as the ground hog, maybe Bill Murray could make a movie about that, (Mole Be Gone Day)
   / Good morning!!!! #54,606
Kyle, the gravel is screened to get the big rocks out, it has a lot os different size particles and after one rain hits it it settles good the sand and smaller gravel seeps into the open spaces of the larger gravel locking it together. It was $290 a load/ Yards?
Insulation does not go next to the metal, the Ice and water shield does and the solid plywood decking and then insulation. I agree with your roofer if batted insulation is next to the R panel which has ridges to allow humidity to enter and then needs air to dry it out. The rolled raised seam does not have ridges so the holes at the end of the panel do not need covering. What type of underlayment is your roofer using?
   / Good morning!!!! #54,607
very productive day, got all my tposts installed, those big guys made it look easy...picked up a whole treeline full of brush and sticks, probably hadn't been cleaned out in 20 years, and now there's room to overseed about two feet closer to the trees. Number of large overhanging limbs, red oak, need to get a real tree person to take them down, too big for the B team. And finally hooked up the solar electric zapper to my rose garden and nicely shocked myself when done. All good.
Nursery in Georgia sending me my fig and nut trees called and asked if they could ship next week instead of this week, said they were getting better stock in. Hmmmm, well sure. Good, another week to get the holes measured and dug.
Very windy out, wasn't earlier this morning, lit the fire in the burn pit, which burned for a while and then almost went out, then the wind picked up and I had to watch it for awhile. Jumped out and burned up about ten sq feet of field, no big deal, I was on the other side of the pile and didn't see it immediately, but the grass is very dry. I had sprayed the whole area down with water before I started but the wind dried it out. No more burning today.
   / Good morning!!!! #54,609
0ーF is to cold for me too but we do get it, that would be -18ー C , with Ground hog day coming up maybe Wiarton Willie will give us some hope for spring.
It doesn't matter what that rodent says, we will get 6 more weeks of winter anyway.
   / Good morning!!!! #54,610
I've had to deal with a lot of such limbs here, as there are too many to be able to pay for someone else to do the work. I use a Stihl pole saw, and start at the outer ends taking off smaller limbs first. Then start chunking up the large, main, limb a few feet at a time, trying to make the cuts some multiple of 18" for the wood stove, and always being sure to stay out of the path of the falling lumber. I can only work an hour or so at a time at this as it's very hard on the arms and neck, but an hour's worth of cutting leads to several more of clean up, so spacing it out actually makes it easier.
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
2021 CATERPILLAR D3 CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
