Kioti DK40SE HST starting problem
/ Kioti DK40SE HST starting problem #41
I'd think that if you unplugged the temperature sensor that it should then engage the GPs automatically (as normal). That's how it works for VW TDIs: the computer falls back to a default value, which is that of a cold engine. At any rate, test the sensor (easy enough); pretty good chance that that's the culprit (if not it, then wiring).
Post 34 (excerpt from service manual) says it's the other war around. Sensor shorts to ground when "cold" and opens when temp is over 60C (about 140F). It's not clear if this is a gradual transition or an on-off switch. The pre-Tier IV electronics are not smart, which makes them easier to diagnose.
/ Kioti DK40SE HST starting problem #42
There's also the issue of what happens when the harness isn't relaying a grounded-out (open) situation. That's kind of my point/question: what's the computer's default? Simple enough to just test (in the name of science:D).
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
2001 John Deere 250 Skid Steer (A62613)
2001 John Deere...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Cat V80C Forklift (A65579)
Cat V80C Forklift...
