3-Point Hitch How do I find balls for my lower 3 point quick attach arms DK 5010?
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #21
Now that's an interesting take on this. I paid EXTRA to get these arms! I've learned from this site that a best practice is to leave the balls pinned onto the various implements. That would certainly prevent them from falling out :)
I recall balls for quick hitches for a Deere CAT II quick hitch --I have some of these balls in the barn--and these are to allow the quick hitch to function by just backing into the implement. These may be different from generic lift balls that go into the arms. I recall they had a small "boss" on each sides of the ball. I will locate this morning and post some pics. I think I also have some lift arm link balls so I'll photo those as well. Let's see if my memory serves me correctly.
If you posted a pic of your lift arms I think it would be helpful.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #22
The balls were used on some British tractors with names like Nuffield and Leyland.
Dave M7040
I miss 'Nuffy', we had a 10/66, with a loader and duals on the back. Useful old girl she was. Go like the proverbial too, I think 27mph flat out? You could get the hand throttle past the stopper and then hold on!!! Great light tractor for spraying on cultivated ground, seeding, etc. Wish Dad never sold it.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #23
Sorry for a slight hijacking of the original post but I am getting all excited talking about Nuffy's.
My Nuffield was a 465 and it served me well. In the winter in Canad where we live it can get to -40F and my Nuffy could not start.
I made an engine heating system from a 4500 watt hot water tank element and a hydronic circulation pump connected into the cooling system.
I had a wire running from my home to the tractor shed to turn on this engine heating system. In 20 minutes the cooling system was up to 200F and the Nuffy thought it was summer and fired right up.
I used it for blowing snow and jammed a John Deere cab on it to keep me warm.
Only thing that ever concerned me during road trips to our cottage with it was braking. You never knew which way it was going to swerve in spite of all new plates and discs.
I am now 70 with a damaged spinal cord and cannot do the heavy maintenance the Nuffy required and bought a new Kubota with cab, heat and AC.
Dave M7040
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #24
Here are the lift balls for a quick hitch I mentioned above. These go on the implement and the tractor backs up with a quick hitch on it and scoops on to these things. This is likely just an early version of the current ones that are a straight shank with a large boss on one end and is pinned onto the implement. I don't know as these things have evaded me in life. So at best I can offer these pics and let others figure it out.
Post a link arm pic and it will be solved. Anyway, here's my pics.
Stole these from another durum here. These are the lift arms and then another of a ball on an implement.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #26
View attachment 496846View attachment 496847
Bingo; problem solved. Looks like regular lift arm balls will fit but the kind with the boss on the end might work better. Basic lift balls are from mail order and mentioned earlier in the thread. TSC, Rural King; everyone has them here so any farm store there has to have them. Common ag item.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #27
Std balls do not work to the best of my knowledge, wrong size. The balls with the small side extensions are top link balls and the other balls are draft link balls. The large flanged balls are for pin type connections and the std balls are for clevis type connections. There are no cat 1 top link balls that I know of, I have to machine the cat 2 balls to work for cat 1 applications.
These are what I have: Ball Replacement Cat II | Lawn Garden and AG Parts
Ask your dealer if he buys from A&I, if so have him order part number A-RB09. I believe they are sold as singles.
I'll be sure to let the dealer know for future reference but I'm going to order these RIGHT NOW. I think you and I have the exact same machine. DK 5010 with the quick attach arms. You're saying these fit in your arms and are what you use? Please confirm and I'm making an order now. Problem solved. Thank you!
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #30
I'm 99% sure those are the ones I purchased when I got my tractor. I just went and measured the best I can with a tape measure and the dimensions match (as close as I can get without calipers). I have a DK5510 but the arms are the same. Just note that those balls have a 1.125 ID so you'll need to use a bushing if you have Cat 1 implements.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #31
Or just buy cat 1 balls.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #32
This is true but for some reason all the cat 1 balls I found wouldn't fit the arms. Also in my case I have both size implements so the handful of ball ends I have with fit either.
I'm thinking I can pin on the balls with a bushing. My box blade has cat 1 pins, my rake has both cat 1 and 2. They're both on the way from EA. Won't a bushing fit over the cat 1 pin and inside the ball?
Forgive my noob logic, this is my first tractor and I've got all of 30-40 minutes operating experience. This weekend was spent practicing moving, figuring out the differences in the various gears, and rolling and curling the bucket.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #34
It should I would think, but then you have things sliding around if much wider than the ball. It's always been my thinking that the balls ALWAYS just stay with each implement.
How many do you want? I have buckets of them.
Think about the QH top link, makes life a lot easier.
I've ordered enough for my 2 implements and yes, they're going to stay put on each.
Don't you make the hydraulic top links? Do you have the sizing for a Kioti DK 5010?
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #36
I do and yes I have the dimensions. If you are interested, please fill out the contact page on my website.
Wanted to provide an update just in case anyone ever faces this problem. Received the balls from the dealer and the ones I ordered that were linked. All too big.
I've learned that the arms for the DK4510 and DK5010 are Cat 1. I'll attach a picture. The dealer apologized and is sending Cat 1 quick attach arm balls now. Apparently he's sold so few of these that even he didn't know what arms came on my machine. If this weren't so frustrating it would be amusing. I've got tools sitting ready to use and cannot connect to them! Once I get a part number I'll get it posted. IMG_3174.JPGIMG_3176.JPGIMG_3177.JPG
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #38
Thanks for the update! I find it astounding that they aren't standard equipment like I thought they were. I thought the other system went out in the 80s.
   / How do I find balls for my lower 3 point quick attach arms DK 5010? #39
r0bg,
Did the dealer have those balls in stock or did you have to order them?
r0bg,
Seems the way it's set up is the dealer places the order for you. You call him, he orders them, they ship straight to you from Kioti in Wendell NC.
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56438)
Bulk Lot of NEW...
John Deere 644J Articulated Wheel Loader (A59228)
John Deere 644J...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
