Used Tractor
/ Used Tractor #1
martialplumber
Portland,ME
2002 Kubota L4610HST-HC
I am going to check out a 2002 Kubota L4610HSTC2 46hp hydrostatic. Factory cab with heat and AC. Equipped with a LA852 loader. Excellent condition with ONLY 253 extremely low hours asking 23,900. Is there anything I should check on this model.I did talk with the dealership about the hours and they said the previous owner bought it new from them and just did not use it, he just traded it in on a new machine.
/ Used Tractor #2
L4610 SPECS: TractorData.com Kubota L4610 tractor information
L4610 is a previous generation, heavy chassis, Kubota 'Grand L'.
I have the smallest of the current Grand L generation, an L3560.
Kubota Grand Ls are top-of-the-line, heavy built, medium size, tractors.
Outside storage vs barn or other inside storage should influence the price. Long term outside storage creates potential for rodents to chew wiring on any tractor.
I am NO expert on prices for Cab equipped Kubotas.
TBN ARCHIVE: Google - Kubota L4610
I perused your previous TBN posts. Cabs with heat are wonderful for snow removal. Cabs are delicate. Most would not take a cab tractor into woods. You may wish to consider a PTO powered Forestry Winch for the Three Point Hitch. Then the tractor can remain on relatively open ground while you winch trees from some distance away.
How many hours have you operated a tractor?
/ Used Tractor #3
If you take care creating thread titles, germane threads will appear in the SIMILAR THREADS box at the bottom of this page.
Used L4610 Tractor, rather than "Used Tractor".
/ Used Tractor
jeff9366 This would be my first tractor I would be using it mostly to clear snow and maintain my 1/2 mile long driveway it would rarely be in the woods if ever and yes I would use a winch if I had to retrieve any timber that was in the woods.So I really want the cab for the winters when I am doing the snow clearing.
/ Used Tractor #5
It is nice to start with THE BEST as a first tractor. Finally, someone buying ENOUGH TRACTOR in the beginning.
L4610 will feel huge the first 20 hours you operate it. After 20 hours of operation it will seem to shrink. Work through it.
An excellent size tractor for twelve acres of land. Probably challenging soil in Maine.
After you acquire a tractor you will find many more uses for it than you imagine. So will your neighbors.
/ Used Tractor
I have read through out the forums it could be better to go new over used because of the interest.but I am leaning to try and negotiate on this tractor and just pay cash.
/ Used Tractor #7
/ Used Tractor #8
I have been using an L4610 (non-cab), since I bought it new in 2002. It has been a reliable, trouble-free, hard-working tractor. There are no major (or minor, actually), trouble prone elements I can think of.
If you buy it, here are some random thoughts: 253 hours is virtually new as tractors go. I'd want to make sure everything on the tractor is working OK and hasn't gotten bound up by lack of use (controls, linkages, grease fittings, etc.). If it were my purchase, the first thing I'd do is round up the owners manual and give it a full servicing with all new fluids and filters. I'd make sure all of the mechanical stuff was torqued to specs (particularly the wheel lugs and loader brackets). Verify that heat and A/C are in good working order. There's a grease fitting for the front axle pivot that often gets overlooked... make sure it gets lubed. There is a clear plastic sight glass on the rear of the differential housing for checking the HST fluid level. Make sure it's got enough fluid when parked on level surface. Be sure to use only Kubota SUDT-2 HST for hydraulic fluid. Expensive (very), but makes a big difference in smoothness and quiet operation. Be sure you add weight in back... the more the better. It has more power and loader capability than you can use without weight at the back, even if the tires have fluid.
/ Used Tractor
Thanks for the information,I am hoping to negotiate with the dealer and get them to take care of all fluids before purchasing.I have plans to check out a couple new tractors both cab tractors a Kioti CK3510hst and a Massey 1736 I already tested an LS XR3135HC-35hp. Part of me says lets just try and negotiate a fair deal for this used tractor because it has low hours it is a little larger then the others I am looking at the cost,I can pay cash so hopefully that will help.The dealership that has it has an excellent reputation and they are the original sellers and the previous owner bought another tractor from them which I think says something about them.I have seen the tractor and it looks like it has been stored inside.
/ Used Tractor #10
I have this tractor's little brother - an L3710. I would argue that the xx10 series Kubota Grand L's are the BEST tractors ever made for price, simplicity, and reliability. You will love that machine.
/ Used Tractor #11
That is a really nice tractor, and as you get to know it, and understand what you have, I would guess you will be very pleased with your choice. The Grand L machines are nice to operate, and while they probably don't really do more than lesser machines will, what they do is done in style and comfort. Clearing snow will become a pleasure. Are you thinking a SSQA plow? I believe that would be my choice. Snowblowers are good in some situations, but generally slow and awkward overall. Enjoy.
/ Used Tractor #12
If you don't buy it, I will.
/ Used Tractor
Looks like everyone is in agreement that the L4610 is a nice machine,so tomorrow is the day, I have the check list what to look at. What would you guys do on the asking price? And while I am at the dealership I was going to check out a new 3901.But as I have been looking around a good used machine that fits my needs is really hard to find that is why I would like to pull the trigger on this L4610
/ Used Tractor #14
I don't think I would be overly concerned about the price. Sure, if you can save some money, that's great. More importantly, if the tractor seems to be as good as you think, and the dealer is friendly and helpful, the asking price is reasonable enough. A couple thousand bucks will be forgotten over time if the tractor works well for you, and turns out to be the right choice. Until you have some time and experience, knowing which machine is ideal, vs. okay to get by with, is mostly guess-work. If you can, start with "better" and grow into it. I don't know what the L4610HSC sold for new, but likely close to $30K if not more. Taken care of the way you stated, I wouldn't be concerned about the age if the tires aren't cracking from UV exposure. No matter what, we would enjoy photos!
/ Used Tractor #15
I don't think I would be overly concerned about the price. If the tractor seems to be as good as you think, and the dealer is friendly and helpful, the asking price is reasonable enough.
VARMINT: Excellent advice.
/ Used Tractor
Thanks,It is kind of what I wanted to hear, just doing my research I know that the L4610 was a premium heavy duty tractor and I have nothing against someone making a profit.I am going to look at this first tomorrow and if it checks all the boxes I will probably just pull the trigger.Thanks again
/ Used Tractor
Okay not to complicate things but on some more research I just ran across a Kubota 2005 L4330HSTC cab tractor which has 1300 hours for 20k it is in the same area should I check on this one?
/ Used Tractor #18
Sure, but unless it is "pristine" and has been verifiably maintained I guess the 4610 would still be my choice hands down. 1300 hours isn't bad, but two major maintaince's should have been performed along the way, and everything such as the tires will have been used up more.
The more tractors you look at, the more fundamental knowledge you will be acquiring. Stuff like remotes, which for a lot of us are very useful, SSQA (both should have that) and any damage would all factor in. Good lighting is easily and cheaply added by you.
Starting with a very clean, low hour tractor has its charms, even if you will the type of user that doesn't wash or worry about "appearance" in that service will be easier, and you have the potential of holding onto your "investment's" value. Unlike a car or truck, a well-bought tractor that's cared for holds it value. At least in Maryland. You should be able to do useful work with your tractor, and when you no longer need it, recover much of your money put into it.
/ Used Tractor #19
The L4330 may have had more than one owner and has five times the engine hours on the L4610.
When you buy from other than an original owner, you never know how the intermediate owners kept up on lubricant changes and greasing.
The L4610 would only have required a 50 hours service and likely the next service interval was 400 or 600 hours. (But certainly change all fluids and filters, grease and run out 90% of old fuel if you buy the L4610.)
However, it never hurts to look. There is no better time to negotiate price on a used tractor than when there is snow on the ground.
/ Used Tractor #20
If in condition as described, great choice.
CATERPILLAR T40D STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR T40D...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61568)
2016 Peterbilt 579...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A62130)
UNUSED IRANCH...
2005 CATERPILLAR 247B SKID STEER (A62129)
2005 CATERPILLAR...
New/Unused 11ft x 19ft Metal Garage Shed (A61166)
New/Unused 11ft x...
