3-Point Hitch 5085M 3pt hitch very choppy when raising
   / 5085M 3pt hitch very choppy when raising #1
pclausen
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
Hey guys,
My 2012 5085M has developed an issue with the 3pt hitch during raising. It is very choppy, as in, not smooth at all, during the raising of an implement. Here's a quick video I took from the cab. If you look at the cab/window frame at the lower portion of the video, you can see how the cab frame is moving up and down.
JD585M3ptlift - YouTube
The loader is as smooth as ever, it is only the 3pt hitch that is affected. It doesn't matter if it is hot or cold outside, or if the tractor has warmed up or not. I got under 700 hours on it.
Last summer I added some hydraulic fluid (although it wasn't really all that low) and that seemed to help for a little while, but the issue returned within a month or so. Fluid is currently in the middle of the range.
Any ideas?
   / 5085M 3pt hitch very choppy when raising #2
Any particular reason to not have it filled up? The jumping reminds me of lack of oil. Does the hyd filter need to be changed? Maybe the screen needs to be cleaned?
I'll go ahead and top it off just to see if it makes a difference. But if the issue was due to low oil, would the front hydraulics not be impacted as well? No issue with power steering either, but I know that use a separate pump.
The hydraulic filter (and oil) was changed at 500 hours, so less than 200 hours ago.
   / 5085M 3pt hitch very choppy when raising #4
You did not mention if you cleaned the pick-up screen. I assume your tractor has one just like mine does. While not as jerky as yours, the 3PT on my 5210 was not smooth when going up and down. The loader worked fine. I replaced the just the hydraulic filter and the 3PT now moves up and down smoothly. I did have 400 hours on the filter. I was surprised how little fluid I lost just changing the filter.
   / 5085M 3pt hitch very choppy when raising #6
That is strange with having normal loader operation.:confused3:
   / 5085M 3pt hitch very choppy when raising #7
I had that same "choppy" action on my previous tractor. I checked everything and finally discovered that the manual speed knob - raise/lower the 3-point - had mysteriously been almost completely closed off. I opened it up to the half-way point and all the choppiness went away.
   / 5085M 3pt hitch very choppy when raising #8
   / 5085M 3pt hitch very choppy when raising #9
I don't know this for a fact, but if the loader actually takes a slower flow of fluid and the hitch takes a higher flow and "if" there is some sort of blockage some place that is slowing the hyd flow, then it makes sense for the 3pt to lift as it is.
   / 5085M 3pt hitch very choppy when raising #10
Your right Brian, my mind automatically just went all the way to fluids - filters and lastly, pump. In other words, the easy fix first.:laughing:
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
