Looking for info on Ford 550 TLB
   / Looking for info on Ford 550 TLB #21
TSO, Ford replaced all of the hydraulic oils with 134C, then 134D, which is what New Holland uses still. Anything of good grade made for transmission/hydraulic systems will work. Only additive you might invest in, but not necessary right now, is New Hollands' anti-chatter additive for the rear axle. If you have 1-1.5" free play on the brakes, they work and you experience squealing of the brakes when applied, then you can add this to quiet them.
Otherwise, the hydraulic oil is the same for all the systems.
Ok. When searching, I saw something that suggested that the Trans oil might be a heavier requirement fluid than the hydraulic system... but are you saying that I could/should use the same 134c or 134d fluid for everything?
   / Looking for info on Ford 550 TLB #23
Yes, that is what I'm saying. If you don't use Ford New Holland 134D oil, get a good grade equivalent and you can use it in ALL hydraulic systems on the 550.
The transmission/hydraulic oils now are better than the original oil spec for steering and loader/backhoe hydraulics. Now, you could use AW68 hydraulic oil in the steering and loader/backhoe hydraulics as those systems don't have any friction materials, but there usually isn't a price difference between the two and then you have to keep track of what goes where.
What are you using in your Massey for hydraulic oil?
   / Looking for info on Ford 550 TLB #24
Tractor Supply Premium Hydraulic Fluid lists 134 C and D compatibility.
Is this a shuttle shift with torque converter or manual with a clutch? If manual it might require a heavier gear type oil.
JD855, this particular 550 has the manual 6x4 gear shift.
TractorTech ... on my last fluid change I put Kubota S-UDT fluid in my Massey. I only went with the expensive Kubota fluid because I sometimes share implements with a friend who is a very particular and diehard Kubota owner who uses only S-UDT.
   / Looking for info on Ford 550 TLB #26
Kubota UDT is great. It's better than the 550 was designed for, but treat it well and it will work for you!
Well... took me a few hours but I got her running. Had to drain out the fuel tank, which took a while because there was about 5 to 8 gallons in there already. It was definitely old fuel, hasn't been run in at least 1.5 years from what I was told. Put new fuel in, some additive, and a new fuel filter, bled the system.
The battery was indeed dead, while I was working on the fuel system I had the charger on the battery, and then used the jumper cables when trying to start the machine.
As for starting it, I need to do some work on the ignition. Apparently they disabled the ignition at some point because it would shut the tractor off when they put it in gear, or something like that. Instead they added a push button bypass to engage the starter. The bypass switch wasn't working, so I tried Crossing those wires, but they wouldn't allow enough current to engage the starter. Ultimately, I could only start it by jumping the starter solenoid. Not something I love doing but I didn't have an option. That will need to be addressed.
It took some starting fluid but she finally started. Once she was running and burned through the remaining old fuel in the system, she ran quite well. There is no muffler on the exhaust, just a pipe, and she is definitely loud. That will need to be addressed as well.
The Hydraulics felt strong, I was able to lift the machine off the ground. However, they were moving a little slow, though they did get better over the few minutes I was playing with the hydraulics. I will be changing out the fluid and filters anyhow, so I'm hoping that it's just old fluids and once I do the maintenance, the Hydraulics will smooth out. It took a few different attempts to raise the loader boom all the way, the first time it stopped about halfway, then moved a little higher on subsequent attempts.
The backhoe seemed to swing and move very smooth, although the swing control doesn't like to swing to the right. It seems like when you pull on that lever it wants to move the entire lever assembly, but once you hold on to the other levers, and stabilize the assembly, it works better. Probably just some adjustments that I need to make to the linkage.
The transmission seems to work fine, I didn't go through all of the gears but each gear that I tried had no problems moving the machine. I don't think the brakes work, and the parking brake lever rusted off of the assembly. The floor of the operators area is almost completely rusted out. Some work there will be required.
The tires also all took air. The front tires have tubes and seemed to be okay. The rears are pretty cracked so I'm assuming they will be low again next time I go back. But at least for now they took air enough so that I could move the machine around.
But for now the good news is that she does run, and the Hydraulics seem to work. I parked her on the edge of the parking lot and plugged her into the batteryminder. Hopefully that will recondition the battery so that when I finally get a chance to retrieve her, she will start up easier. My current trailer isn't Stout enough to handle her, but I'm still shopping around for heavier trailers at the moment.
Pics and a video... ( the 4th pic is the newer machine they replaced the old 550 with)
Ford 550 TLB first time operating - YouTube
   / Looking for info on Ford 550 TLB #28
Wow, that's quite a cutting edge on the bucket. I suppose they wore the original off, cleaning the parking lot. Pretty much took the wear bars off the bottom to. Easy fix with some flat strap.
Could be some water in the hydraulic oil too. Some penetrate, oil and grease will probably do wonders for the rear controls. I zoomed in close, to see if those fingers were still on it, that dampens the swing. You'll feel it pull the lever back to neutral, if they are. I'll look after bit, and find the exploded view on NH Construction, and put the link on here.
Can you guys see any issues with flipping the rear rims around, to widen the rear stance? Granted it's a new machine to me, so I haven't developed a "feel" to it yet, but it felt "tippy" to me.
   / Looking for info on Ford 550 TLB #30
As far as the swing control problem, before you do anything, get a can of good penitrating oil and spray all the bushings and pins in the control tower, every lever should move independently without the cross rods moving. It may take some spraying and repeated wiggling of the levers and re-spraying, but you will be much happier. Lots of moving pieces, lots of bushings, see link below
New Holland (55) - 3 CYL TRACTOR LOADER BACKHOE (1/75-9/78) Parts Diagrams
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
2015 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2015 INTERNATIONAL...
2019 Freightliner M2 106 AWD Altec AM55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
11' CONTAINER (A52706)
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
