How much ballast is typically needed for a MX5800?
   / How much ballast is typically needed for a MX5800? #11
Also, tangentially, if max capacity is important to
Turbys_1700, I plan on replacing our 5' brush hog with a 6' model that will weigh about 850#or so. It will make good ballast with a low center of gravity. aarolar, it looks like you have the Kubota 1500# ballast box I will consider. Correct? You like it? Sand in it or something else? LukesScreenName, I will check the psi before the MX leaves the dealer. I checked our L3800 and it was at the max. I was hoping to increase the psi to increase the FEL capacity but that didn't work, which led in a roundabout way to the decision to get the MX.
Thanks again to everyone for the feedback.
   / How much ballast is typically needed for a MX5800? #13
No sir I built it myself, it's full of concrete.
http://www.tractorbynet.com/forums/showthread.php?t=373072
I desperately want some wheel weights like tripleR has even though I don't feel under weight with loaded tires and the ballast I certainly wouldn't mind even more weight when I get the chance.
Wow, great job on the box, aarolar. Obviously, you can weld and work with sheet metal. I have never welded a single thing but I am thinking of buying a beginner's welder and learning how. I had a dedicated 220v outlet installed in our shed just for that purpose. If you have time and are willing, send me a PM and give me some suggestions for a starter welder. Thanks much.
   / How much ballast is typically needed for a MX5800? #15
lots of 3PH weight ideas on TBN. My 710# ROBB is not enough weight on the back of my 7200# tractor with filled tires and I decided to build a weight box using a 15 cu.' job site tool storage box on a 3PH fork set a friend donated for the project. I am adding a 36" long 2" trailer receiver tube through the box which will tie to the fork lower cross bar. Will also add cross pieces to the 2" tube for added resistance once the concrete is actually poured. I am going to start with adding 750# of dry concrete bags which should provide ~ 1050# of weight. This will allow me to test usage with a heavy FEL and without before mixing the concrete. Will try and strike a balance where I can leave the weight box installed even with light FEL loads without taking too much weight off the front axle causing handling problems. I will still have plenty of room to add large rocks as needed for temporary max FEL capacity.
Starter welder? I am NOT a welder, but can do whatever I need for my usage. Had a 110v unit years ago and would recommend you stay away from that. I purchased a Miller 211 MVP and it makes me look like a better welder than I am when I take my time and do my part. Not inexpensive, but a fine piece of equipment. I use mine in automatic mode and let the machine chose the settings.
I cut the forks with a new Eastwood 60 amp plasma cutter. I almost got a Lincoln on sale for $1500 with rebate from Lincoln and am glad I went with the $650 on sale Eastwood. Not much experience with it but have cut 1" bale spear with it, but it was not pretty and took awhile to do so. On lighter material it does a fine job. But I am still learning how to run it and have more dross (slag) than I like. Will get more experience cutting the 2" receiver tube and support parts. If my uses were not just intermittent I would have purchased the Lincoln instead.
Work in progress and hope to test in a week:
Thanks for the info, sdef. I will look into your recommendations, and I will check back to see how your project turns out.
   / How much ballast is typically needed for a MX5800? #17
What type of stuff do you plan to weld? If no prior experience, I'd probably say stick or wire-feed using flux-core wire. I had only stick-welded and not for 20+ years, and when I got back into it I got a wire-feed machine and used flux-core wire. In no time I was making great welds (although more complex joints or orientations are still a challenge).
I wouldn't be afraid of the 110V units as long as you buy good quality and are OK with welding 1/4" material or thinner. They are great starter machines for under $500 new. Don't waste time/money on welders that are $300 or cheaper. Some people have had luck with them, but they are just not consistent/reliable from what I have seen.
   / How much ballast is typically needed for a MX5800? #18
If you want to beat the heck out of the front end, a 900lb ballast box should be just fine. If you want to max the loader and not beat up the front end, something like 1,500lbs is more like it.
I built a 1,400lb ballast box (weighed) for my LS which has a similar loader capacity to the MX line and it was like night and day. Loaded tires keep the rear wheels on the ground, but only allow you to abuse the front axle. You won't know it for a while, but you'll pay for it in the end.
   / How much ballast is typically needed for a MX5800? #19
With my 700# 7' rear blade and loaded R1 tires with WW fluid, I can lift the back tires if I am picking something that is too heavy....or trying to pry out a log/root/stump or other immovable object. That means I am getting the full force of whatever force the loader can exert before the back tires come up + the full weight of the tractor + the full weight of the ballast in the tires + the 700# blade on the back......ALL on the front axle. While Not having any weight box on the back actually loads the front axle LESS than having weight back there, but not having enough of it. R1 vs R4 as well as liquid of choice make a different in weights. R4's hold more, Beet juice is heavier than WW fluid. I think I got something like 48 gallons of WW fluid in my R1's. So I've only got ~750-800# in the tires. But thats for traction when plowing, and stability. SHOULDNT be relied on for countering the front loader. Again, I am talking about doing heavy work though. Hard digging, logging, prying on stumps, etc. If you are just moving loose dirt, a bucket load of that is ~50% of what the loader can actually lift. Or if you are lifting ~800# implements off a trailer, moving around a bucket load of firewood, pushing brush piles, etc......all I would consider lighter work that dont involve lifting near max capacity. In which case, 750# should be fine.
How much difference would your bush hog make to the load on the front axel? The bush hog might allow for heavier loading of the front axel because the hydraulics weren't maxed out before. Even if you were lifting the exact same load on the FEL you haven't changed the front axel weight by more than a few hundred pounds. Proportionality that's pretty minor. The absolute best thing you could do for you front axel would be taking it out of 4wd. It's possible to load the front axel far heavier ( assuming there's adequate ballast in place ) by backing up while the loader is unmovable. Not to mention all of the binding that occurs.
   / How much ballast is typically needed for a MX5800? #20
Loaded tires AND the 700# blade would just barley lift the rears. I could get to 2400 psi on the hydraulics the the rears would lift. My system is only 2500psi. So I'd say 800# would max out the loader, and just barley leave the rears on the ground. At that point....That is the most the front axle can see. All the weight from the tire ballast + tractor weight + blade weight + loader and load.
The bushhog is 1600+, and hangs farther back than the blade. So I'd day the difference the front axle is seeing is significant. Also noted by the non-scientific visual reference of front tire squat
2004 Woodchuck Altec AT37G 37ft Insulated Rover Bucket Lift (A55852)
2004 Woodchuck...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
Water Pump w/ Hose (A56469)
Water Pump w/ Hose...
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
UNUSED JCT HYD VIBRATORY PLATE COMPACTOR (A57193)
UNUSED JCT HYD...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
