Need Help With Hole Spacing On 3-point Stabilizers Please.
   / Need Help With Hole Spacing On 3-point Stabilizers Please.
Here's a shot looking down over the lift arm with it pushed all the way out against the tire sidewall. Note the short length of the turnbuckle type stabilizer. The lift arm doesn't normally have to come out quite this far, however, even when attaching/detaching 3PT implements.
Note the tilt cylinder that I had to modify to fit in this confined space.
   / Need Help With Hole Spacing On 3-point Stabilizers Please. #12
Look for use of stabilizer bars top left of page six and I think a reason for a slot on stabilizers will become a little more into focus. http://www.farmstar.com/Manuals/hk1106fs.pdf.
I usually put the pins in the middle of the slot on each side when plowing. (Turning land)
Nelson:
Here's a somewhat different way to do stabilizers. It makes a 3 point into a self centering hitch. This is on my B7500 but was copied from an IH 686. The orange center bracket pivots depending on the width of the arms to keep them centered.
457172d1455571623-adding-telescopic-stabilizer-kit-worth-hitch-jpg
That's another new one for me, Richard, had not seen anything like it. Are you using that with a quick-hitch? Does that act like a somewhat rigid stabilizer since the lift arm ball ends would be captured?
Thanks for posting. Interesting.
This is on a Deere of about the same size as my B9200 with somewhat similar confined space next to the tire. I'm surprised at how light it is constructed with the outer telescope member being 3/4" x 1 1/2" x 1/8" wall rect tubing. (Probably metric actually) That leaves about 1/2" x 1 1/4" max for the inner flat member. The tube is slotted where the pin is located. The lift arm has the double offset bend in it like so many of the compacts do. That leaves more room for the stabilizer than on my Kubota with the straight lift arms.
   / Need Help With Hole Spacing On 3-point Stabilizers Please. #15
Short answer .... yes and yes. I do have a Pat's QH on it now but not when this was originally done back in 2004. Since both links are fixed it acts like a rigid stabilizer but the width can change to whatever size the implement wants. It makes hooking up much easier even without the QH because both arms move together as the width changes. After using the IH 686 which was that way from the factory (and an IH 584 that wasn't) I got spoiled and made my own for the Kubota. I was a little concerned when I made it that the 1/2" all-thread wouldn't be strong enough but it has lasted over 10 years without any problems.
   / Need Help With Hole Spacing On 3-point Stabilizers Please. #16
Understand that if properly constructed the "sway" load is shared between both arms. So the stabilizer is never handling that load by itself. It always has the other one splitting the forces.
I run my telescoping stabilizers pinned with no lateral movement 99% of the time.
I don't understand never pulling the pins? How do you hitch to implements?
That's something I've been wondering about--"load is shared" and exactly how that "ties in" with hole position increments in the stabilizers. Looks like it would be accidental if both lift arms were up against a stop on their respective implement lower pins. It seems like one arm would have to float a little on the lower pin in order to get the pin in one of the stabilizer holes. Probably depends on how much slack in the stabilizer holes?
I've used the telescoping type stabilizers only a couple times and never really gave it much thought. I do recall having to use the slotted hole on one stabilizer because none of the holes would line up. Perhaps should move the lift arm in or out a little to allow the pin to drop through a set of holes prior to first lifting the implement. But then it looks like one stabilizer might be bearing the entire side load.
   / Need Help With Hole Spacing On 3-point Stabilizers Please. #18
I raise the implement off the ground. Then pin one to center the implement. Then push the implement side to side until the other pin fits. I prefer that this happens at one side or the other. In that scenario both telescoping links will share the load.
   / Need Help With Hole Spacing On 3-point Stabilizers Please. #19
One more thing, if you pin one arm in a round hole then pin the other in a slotted hole you might as well have put the second pin in the tool box because it's doing nothing... :)
Richard--I'm wondering about the necessity of having both stabilizers "locked in". Consider that, on a turnbuckle stabilizer system, only one of the lift arms at a time is carrying the side load. That would be the side in tension as the turnbuckle is non-functional in compression.
1996 Ingersoll-Rand VR642C (A47477)
1996...
1831 (A51247)
1831 (A51247)
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2019 CATERPILLAR...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
