Blue-tooth Adapter
/ Blue-tooth Adapter #1
Silvic
Gold Member
West of no-where
Not exactly tractor related but know there are some folks on here that have a variety of backgrounds that can answer the question.
I have a device that has a serial connection data output. (Yes they still make those in this day and age.
It is actually a Hirose 6 pin connector on the device that can either go to a RS 232 type plug or an USB connector on the other end. (Two different cables are available)
If plugging in to a computer only the USB would be the best choice but what I want to do is put a blue tooth on the end so that it can communicate with other bluetooth equipped devices.
I have searched for RS232 equipped bluetooth devices and there are many. There are also USB bluetooth devices in many varieties but it seems they are more for giving a computer with a USB port a bluetooth capability than some device with a serial output.
My problem, from what I have found in my research, is that the output from the 6 pin serial output does not appear to have a power supply in the 6 data wires thus the blue tooth device that is RS232 capable would not be powered. I hope that I am wrong but how does one get power on the blue tooth device if that is correct. Does anyone know of a portable small RS 232 bluetooth adapter that has an internal power supply. By portable I mean small enough that it would be under 16 oz/1Lb or that has a small battery adapter that can be attached to supply the power.
This is a bit outside my normal area of knowledge thus am turning to you folks hoping that some electronic/computer whiz will know or has done this. Apparently there is a market for putting bluetooth adapters on older legacy serial devices to be able to communicate with them via wireless. That is basically what I am doing.
/ Blue-tooth Adapter #3
BB electronics or digicorp are likely to sell those as well but that amazon price isn't bad.
/ Blue-tooth Adapter #4
The Bluetooth adaptor won't know that it's not connected to a computer, as long as what's coming out of the cable to it is correct RS232 signals or USB protocol. I assume the USB cable is a RS232->USB adaptor and it serves as a USB hub. I'd get an RS232 bluetooth adaptor as that's one less conversion than with the USB version. And RS232 is a lot less complex than USB.
If the device isn't powering the RS232 you can do it with a power supply. One of the RS232 pins is power. I used to know which one but it's been a long time since I made RS232 cables. You can cut apart a cable or get a kit to make cables, and connect the power pin to your power supply or battery.
/ Blue-tooth Adapter #5
USB is asymmetrical. By that I mean there are two types of USB devices, hosts and peripherals. Basically a computer is a host, things that attach to it are peripherals. The host provides the power and controls the connection. The problem is you're trying to attach two peripherals.
RS232 is symmetrical -- you connect two devices together, they both send and transmit as equals. USB is backwards compatible with RS232, with the proper adapter you can connect a RS232 device to a USB host as a USB peripheral. The bluetooth USB adapter you're looking at is a USB peripheral. What you need is something that is a USB host to attach your device to, and then some way of getting data from that host to where you want it.
I think what you should be looking at is wireles RS232 extenders.
I don't know what your budget is or application, but this might work or give you some ideas. I found this doing a search on Amazon for "bluetooth converter for rs232"
Amazon.com: RS-232 To Bluetooth Converter
I looked at those but they wouldn't run unless pin 9 has power to it which I don't think is the case with only 6 wires out of the Hirose plug to the 9 pin.
There are ones that have built in power but they get real spendy
I think what you should be looking at is wireless RS232 extenders.
I did not know that there was a RS232 wireless adapter (extender) Will have to look at that and see if they are available with self contained power. Would guess they may burn a bit of power/battery however.
KUBOTA L3901D TRACTOR (A64280)
KUBOTA L3901D...
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
Roll of Barbed Wire (A64119)
Roll of Barbed...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
