Problem with new bucket on 2650
/ Problem with new bucket on 2650 #1
mpham
North/central Massachusetts
Kubota B 2650 cab
Tried to scrape my driveway yesterday and I kept getting ice left behind. Checked the bucket and the edge is not straight. Anyone else see this before? I sent an email to the dealer, waiting for a responce.
/ Problem with new bucket on 2650 #2
Looks worn on that side. It could be a little crooked to start, causing wear on that side. Or you may favor that side and not know it.
Oh sorry, now I see it says new. Nevermind. I can't read!
/ Problem with new bucket on 2650 #3
It looks to be made that way,,, what does the other side look like?
Maybe a defective cutting edge was welded on?
/ Problem with new bucket on 2650 #4
There are so called Spade Nose Buckets. Do both ends of cutting edge look the same?
Yah. Only 9 hours on the machine and I have a plow and blower. First time I use the bucket. It appears ok on the other side.
/ Problem with new bucket on 2650 #6
The guy that made that bucket did that one before his morning coffee,,,
/ Problem with new bucket on 2650 #7
Looks like it is worn. Guess some metal splinters are visible in the pic 1.
/ Problem with new bucket on 2650 #8
Good catch. From the looks of it I would say it was drug backwards. Our 2650 bucket is straight as an arrow, even after 270 HARD hours.
/ Problem with new bucket on 2650 #9
Yeah, if you look carefully it has been worn down in that corner somehow. The edge itself looks like it was straight (based on the "facet" feature line you can see in the photos)
I have seen some cases where the edge wasn't stitch-welded perfectly and bowed a little, but this one definitely looks like wear due to the metal curling up there.
Is it possible the bucket is not level and that caused the excessive wear in that corner? Check tire inflation to make sure left and right (on both front and back) are the same.
/ Problem with new bucket on 2650 #10
I used to buy several tons of cutting edge at a time, similar to that,,
The bevel is rolled on the edge.
Occasionally, a defective end would show up.
It looked like that. It was rather common.
The cutting edge should have been culled and scrapped,,
but, the welder was probably the "inspector",, he missed it,,,
It's not warn down it looks like it was ground with a tool to match the bucket edge. It and the tractor are new with 9 hrs on it. This is the first time i put the bucket on and I didn't back blade with it. Have had a plow on it since purchase but the ground was to soft so decided to try the bucket.
/ Problem with new bucket on 2650 #12
Have you contacted the dealer?
If you can take bucket to dealer show them also state 9 hours on tractor.
/ Problem with new bucket on 2650 #13
Looks like that to me also, measure the depth of your bucket, it could be shorter on one side.
/ Problem with new bucket on 2650 #14
My guess.....I say guess.....is that the edge was straight when brand new and the nine hours was on a concrete surface wherein that edge of the bucket was lower. Thus the nine hours just ground it down. Several causes have already been mentioned.
/ Problem with new bucket on 2650 #15
mine looks like that at both ends but I have over 650 hours on it and probably half of it plowing snow on blacktop.
My 6 year old 800 hour Kioti bucket didn't look like this and I actually used that. I did some measuring and it is 1/4 inch out of square. The middle of the edge measures 21 1/2inches. The left edge measures 21 inches. The right edge measures 21 1/4. Looks like it was welded on wrong and ground to fit the edge of the bucket. Don't know why everyone is saying it is warn. The tractor has 9 hours, the bucket has 20 minutes at most. Still waiting to hear from the dealer.
/ Problem with new bucket on 2650 #17
Same here with about 500 hours....probably 250 doing snow on gravel and concrete as well as using the FEL for moving gravel and dirt. My FEL arms (bucket) were a little askew about 1/2 - 3/4 inch when the unit was new. But it leveled out (tweaked) after awhile.
I hope the dealer response is helpful, Phil.
/ Problem with new bucket on 2650 #18
I think it has to be wear -- look at this photo from your thread when your 2650 was brand new -- the bucket edge looks OK to me. That suggests the wear and tear had to come afterwards, and it wasn't like that originally.
Now, it's hard to tell from the photo, but either the floor has a high spot at that expansion joint, or the bucket edge is a little bowed (which can happen from welding). If it was indeed bowed (or your tire pressure is not even) and you pushed it around on a hard surface, maybe the corner wore down faster than the rest of the bucket. Definitely check your tire pressure as it's a common cause of stuff being off-kilter and wearing unevenly like that.
489349d1480156287-new-kubota-2650-came-img_1393-jpg
Ok. Warn side had 27 lbs. other side had 24. Manual says to run 22 so that is what I made them. Could it be just not hardened correctly? My concrete driveway is pretty aggressive with a broom finish.
/ Problem with new bucket on 2650 #20
Make sure you check all four tires, as any of them can cause the bucket to be off kilter. I dont know how hard the edges should be, but that amount of wear could be done in minutes with a grinder. Concrete on steel -- with a lot of weight -- surely is comparable.
