Gravel road install- diy with no spread by dump truck?
   / Gravel road install- diy with no spread by dump truck? #21
All the ten wheelers around here that deliver gravel have an extra "flange" type thing on the back of the body.
Kinda like this,,
Without it,, the material comes out too fast to spread,,,
   / Gravel road install- diy with no spread by dump truck? #22
This is how N O T to deliver and spread gravel,,, :laughing:
   / Gravel road install- diy with no spread by dump truck? #23
This is MUCH better,, notice the tailgate flange??
   / Gravel road install- diy with no spread by dump truck? #24
I always ask for "Jenny" when I need gravel delivered, since she can spread it out of the truck like a pro and it takes minimal touchup with the tractor. Her truck tops out at 16 ton loads I believe (ie, not a tri-axle). We also get a kick out of seeing this older gal driving a dump truck (she looks like she could be someone's granny).
For smaller loads or where a truck can't get in, I have them dump it at the end of the drive and bring bucket loads in with my tractor. Can do a decent job spreading by slowly dumping bucket while reversing, or just dump and then back drag. Spread it as good as possible and then start going over it with the box blade. Much much less efficient than when the truck can spread it, but doable.
   / Gravel road install- diy with no spread by dump truck? #25
   / Gravel road install- diy with no spread by dump truck? #26
20 tons isn't that much to do. Have the first dump at or near the top or house and the second about 1/2 way to the road. The box holds more than the bucket so you won't use the bucket much. If you can get at least a hydraulic top link things will be much easier. Otherwise set the box about 1/4"-1/2" from cutting while going forward. Back into pile, bury and fill box, then drag and spread as you go.
Once everything is prepped with an edge along your driveway and smooth, spreading this should be a nice little project that will take less than a day to spread.
Btw- I would rarely have the dump and spread routine done. Far to many variables and in my area the drivers were an unknown as well. I'm not saying it doesn't have a place. Just with a little drive like this it isn't saving much.
You will also want some size in the material delivered. Typically it's 5/8" or 3/4" minus. I'm not sure what your plant is calling crusher and I don't think all 1/4" minus is best for a road.
X2 20 tons isn't that much to worry about.
   / Gravel road install- diy with no spread by dump truck? #27
Kinda like this,,
Actually the "lip" extension has nothing to do with the speed of discharge. That is controlled by the chains on each end of the tailgate which determine the width of the tailgate opening.
The lip extension is needed to dump into equipment such an asphalt spreader.
   / Gravel road install- diy with no spread by dump truck? #28
Here they usually ask how many links you want to use.
Once had a driver that could lay out an impressive even depth except one day he forgot to look overhead as he carefully played with his gas peddle to control the coverage.
Rather than looking above he hung his head out the window to monitor his progress.
As you guessed it, he hooked a tree limb with his raised box and down came the limp, dented his cab and jammed his door closed.
His only comment was , WOOPS.
About the most laid back guy I have met in a long time.
Since then, over time, I have either used him or directed many many loads his way.
   / Gravel road install- diy with no spread by dump truck? #29
Richard beat me to it! I'm on the West coast and I just woke up :D
Terry
   / Gravel road install- diy with no spread by dump truck? #30
Terry
WAKE UP AMERICA!!! :)
Around here they bolt on the extension. If not dumping into a machine they take it off. Pounds are money.
204549 (A52707)
204549 (A52707)
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLANCH...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
40' CONTAINER (A58376)
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
2020 CATERPILLAR 259D3 SKID STEER (A52709)
2020 CATERPILLAR...
