Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #4,321
Absolutely beautiful photo dragoneggs, Wish I could say the same about the picture of my driveway yesterday... I did use the tractor to pull some big limbs off the door to my wife's chicken pen.:) It was still too dangerous to remove limbs under the trees.
/ Tractors and wood! Show your pics #4,323
There's not much you can do to help yourself with freezing rain and that's one of the things that really sucks about it. I hope you're melting safely.
/ Tractors and wood! Show your pics #4,325
Nothing worse than an ice storm dirt ditch. Having to just sit and watch the destruction and then when it is over sit some more until it all melts is a killer.
gg
/ Tractors and wood! Show your pics #4,326
I like the pole barn set up. I need to do the same this summer. What are the details of structure?
Here is my tractor and my wood :)
/ Tractors and wood! Show your pics #4,327
Here's my process, using my tractor, winch and excavator to cut, pile, clean up and make woods roads...
/ Tractors and wood! Show your pics #4,328
Well finally above freezing and not raining. So... here is my tractor and wood pic... yeah it's only the xmas tree going down to the burn pile. Hope this counts! :D
Beautiful view for a burn pile... :D
I put our old tree in the brush area behind our property. I stand it up and it stays green until spring. There's about 21 of them back there now. I can only see about 2-3, the rest rot down to dirt pretty quickly. The little birds like to sit in them in winter. Good cover.
/ Tractors and wood! Show your pics #4,331
We were burning some piles last week when he weather was cooperating with snow. Trying out some techniques to make biochar from piles of slash.
Also used the winch to flop over all the stumps to get the soil back in place before they are burned.
/ Tractors and wood! Show your pics #4,333
Yeah it's not hard to come up with an excuse to burn at my place. Often I drive my tractor next door and scoop up my neighbor's burn pile before he gets to it and put it on mine if I'm burning. One time I asked him if that was okay after I realized I might be stealing his pleasure. :laughing:
/ Tractors and wood! Show your pics #4,334
In Thurston we have burn restrictions and need a permit if I remember correctly.
Anything like that were you are?
/ Tractors and wood! Show your pics #4,335
Kitsap County has free annual burn permit. Only restriction is size of fire and distance to structure/trees and must have water source nearby. No adding to existing fire after dark. Usually around July 4th or whenever it really dries up the county will put on a ban that lasts until October or whenever the rains come.
/ Tractors and wood! Show your pics #4,338
That looks like a fun piece of equipment. Was that you that posted about it a couple years ago?
Yes. It's a little trencher that has had the trencher portion removed and a hydraulic winch installed. I've also added a extension to the 6 way blade and foamed the tires and added a set of chains.
I do small jobs with it skidding trees and cleaning up messes after fires and wind storms. It was kinda funny on this latest job I got stuck pulling up the steep and narrow driveway coming up a canyon. I drove the skidder off the trailer and even then I could not get enough traction in the truck to get going. Ended up dragging the 2500 Dodge and trailer up the hill with the little skidder. When I get to the house the homeowner had gotten her suburban stuck pulling up the driveway as well. I ended up pulling her suburban up the hill. It's quite heavy for it's size (just the tires and chains weigh almost 1,000) and it has 600 pounds of counterweight on the front. I'm guessing is weighs around 5k pounds. It's certainly not a replacement for a real skidder but it is much more capable than a 4 wheeler or UTV when it comes to pulling logs. The little 31 hp deutz has enough power to do some work and it's pretty amazing what it will pull in low gear (3 speed tranny). I bought it to use instead of buying a 3 point winch for my tractor. It has a much lower center of gravity and works well in the hilly terrain around here.
If you quench your fire when it turns into coals and before it completely burns up you can make a valuable soil amendment called biochar with your brush piles
/ Tractors and wood! Show your pics #4,339
I've been thinking about sifting through the ashes from my stove and add the biochar to my garden beds. I guess I could build a fire then put it out and make a bunch. Is there any type of wood that works better?
/ Tractors and wood! Show your pics #4,340
Yes. The dry kind. I don't think the species make a huge difference.
You can also make biochar in your stove by putting wood in a box inside your stove. A section of stove pipe and a couple of caps works well. Similar to this.
Biocharlie Biochar Log - Make Your Own Biochar in a Fireplace - Blue Sky Biochar
You could also dig a trench or pit in your yard to improve yield
Ideally having the same sized material works best for making biochar but you can just push the bigger pieces to the top or simply pull them aside and let them burn out while you quench the main pile of biochar. Here is some information I used when I was getting started.
Backyard Biochar: Top Lit Open Burn
Piles like this are pretty easy to manage by hand and a hose could be used to quench.
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
