Question for those with cabs
/ Question for those with cabs #1
cford36
Gold Member
Western, NY
LS3135HC
Anyone ever find a place to get the plug and pigtail that would go into the spot for the beacons?
/ Question for those with cabs #3
Probably would help if you named a make,model and year of your tractor.
Well LS since this is the LS group.
2016 LS3135HC
Just assumed all the LS cabs had the same beacon connection.
I'm referring to the plug in port on each side near the beacon mounts.
Want to put other lights back there and would be easy to plug into the ports since they are wired to a switch already.
This is the plug on the beacon.
That's the port.
/ Question for those with cabs #6
I don't believe that's any regular kind of power port. I seem to recall the manual stating that it is for a beacon only (at work, so I don't have it in front of me). That may be regulated to pulse the beacon. A quick check with a meter could confirm that.
Good point I'll have to check that.
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
(2) Lights (A64119)
(2) Lights (A64119)
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
