What's the Best Farm Truck to Haul my Tractor and Cattle with?
/ What's the Best Farm Truck to Haul my Tractor and Cattle with?
to make the best recommendation as far as truck we need a better idea of the actual use for these tasks are for a hobby farmer or a real farmer/rancher. If you have say 5 cows and move them to a summer pasture and back each year that is one thing and completely another if you move large numbers of cattle on a regular basis. Same with the tractor. Is this something you do a few times a year on "homeowner" type of tasks or is this doing regular work hauling your machine for jobs such as bailing hay or brush hog work. If this is just a hobby and you have a few animals as pets on a small acreage you can certainly get away with less truck. If you do this for a living and need somethign that is more dependable you probably need to spend more up front.
In the original post I said I need a truck to safely haul 7500-10,000lbs and is really dependable.
So I guess I will add that I'm hauling something on a weekly to monthly basis possibly, I plan to haul my tractor around in the summer more often for different jobs, not daily.
Distance majority of the time is 1-50 miles.
I'm not looking to "get away" with a lighter truck, I want to safely haul the weight. Frequency of hauling is kinda not relevant. Unless I was hauling far distances daily which I'm not.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #42
Diesels are expensive for what you're wanting to do. It's the little things that eat you up with a diesel on a regular basis. Injectors, turbo, pumps, etc. All of these little fixes can be thousands of dollars. Or, you buy an old 7.3 with 200k and the engine totally gives out and the thing is basically totaled. Like others have mentioned, I'd find a nice Ford V10, 454 big block chevy gasser, or a Dodge V8 or V10. Gas is so nice; they start when it's cold without being plugged in or having glow plugs, etc. They don't need to be warmed up for 20 minutes in the winter. They aren't loud and heavy. If they blow up, it's a couple grand to pop a brand new engine in them. At the weights you're talking, on flat ground, gas is a good way to go. No one wants these bigger gas trucks anymore due to the simple fact that they are not fuel efficient for any projects other than the narrow spectrum of work which you have found yourself in. Fewer and fewer people are farming or working on a small scale. For most small stuff, an F150 works. For big stuff, you want a diesel. So, because of this narrow range of weight you are working in, you can pick up a nice 250/350 gasser with 100k on it for dirt cheap and if you maintain it and go easy on it it'll probably run for 40k more without an overhaul. That's my two cents anyway. When I started out I bought a 94 dodge cummins with 205k to do what you're talking about doing. I got lucky and it ran great and never really let me down... but the starter failed and that was $600... and it leaked oil everywhere and to fix it would have been a heck of a job... and it was so loud I wanted to wear ear plugs when the windows were down... I am shying away from diesels now. I run a Volvo road tractor to haul heavy loads and use gas V10s for route trucks. The Ford V10 has been a good engine for me. Cheap to fix, cheap to maintain, doesn't complain, few issues... plenty of power for 8000lbs towing... late 90s Ford V10s are solid machines... Just my thoughts.... good luck
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #43
THere are several 7.3 diesel engines made by International that were in Ford trucks.
Big difference in power between a naturally aspirated IDI and an 03 turbo intercooled Powerstroke
Sorry, I should have added that it is an 03 turbo 7.3.
1931 Ford AA truck
Think I can install a 5th wheel hitch? Lmao JK, cool old truck though
Other than the 6.4 part...yes way better, 6 speed manual too.
6.4? I can't zoom in that far if it says it on the truck what motor, it's a nice truck but I wouldn't want a crew cab, too long of a truck
Ford SuperDuty F25 4WD LOW MILES No Rust Runs Good
I think that's the type of truck I would buy if I had any money right now, and if the truck wasn't a salvage. Just a simple 3/4-1ton work truck.
I don't think I would want a flat bed but would be open to it.
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
