CT230 electrical issue
/ CT230 electrical issue #1
lstinthot
Spotsylvania, VA
CT230
I have a Bobcat CT230. Will not turn over with switch. I checked the fuses and the 5 amp fuse to the safety circuit was blown. I changed it, still would not start with the key. Jumpered the starter and it started and ran. Turn tractor off, try to start it again, no luck. Fuse not blown. Sometimes you can hear the pull up relay pick up sometimes not. Every once in a while I can get it to start with a jumper at the starter. Now the 5 amp fuse is blown again. Not sure what is blowing the 5 amp fuse. Might have been my with my volt meter checking voltage at the operational control unit.
Any way to test the operational control unit? I get the PTO light when I engage PTO, it goes out when I disengage the lever. I jumpered the switch for the travel pedel. I jumpered the seat swich.
No voltage at the start relay. I can use a jumper across the start relay and start it there when it wants to start.
I checked the switch in each position using a continuity check. Blue/yellow wire to red wire circuit closed with switch in start. Red wire to red/blue closed with switch in glow plug position. Red to red/white closed with switch in run.
Mike
/ CT230 electrical issue #2
Maybe you don't have a front pto but if so is that safety switch working?
I do not have the front PTO or Mid PTO. I just pulled the jumper out that is prewired for the mid PTO and the light on the dash turns on with jumper removed, which tells me the control unit is seeing the change in state. Good thought, I had not checked that one yet. Still no go on engine start.
/ CT230 electrical issue #4
I am convinced your electrical skills are above mine, wish I had more ideas for you. For my information, what is the "control unit" you mention and where is it located? I haven't been able to find it in my manual.
/ CT230 electrical issue #5
Seem strange you can jump the stater and have it run, Is the seat safety switch working? How about the go peddle one and others. On mine I have become accustomed to tapping the go peddle to get it to start if I turn the key and get a no go, There are several pinch points on the wiring harness, Just follow it from the IG switch to the starter relays and on. Cold also be the relays on the firewall. There have been several posts on swamping them around to find the source.
/ CT230 electrical issue #6
First step is to completely remove the negative battery cable, clean both ends and the connection to the frame. The do both ends of the positive cable and check for corrosion under the insulation at the battery connection. Put the negative cable back on last.
My favorite starter troubleshooting video: Starter Voltage Drop - YouTube
I will have to try that. I just replaced the positive terminal connector about a year ago and cleaned everything then. Connections are still tight and clean, maybe there is fouling under one of them. It is acting like a intermittent ground.
When I was researching this issue this time, I came across another thread I posted where the tractor did the same thing when I first bought it. I had forgot about it until I read the thread. At that time it only took a couple hour break then started working again. I never did find what caused the non starting that time.
/ CT230 electrical issue #8
Have you tried spraying electronic contact cleaner into the ignition switch and then trying to start it? If that solves your problem then get a new switch and spray it with fluid film before you install it. Save the old one for tear down and clean up spare.
I have sprayed the switch with cleaner.
/ CT230 electrical issue #10
Other than clean up all connections and maybe coat them with dielectric grease before reassembling, I got nothing.
I found the issue. Went back to check voltage at the operational control unit from each safety switch. Turns out the travel pedal switch was not sending 12 volts to the control unit. Took a resistance reading and in the process saw some chewed wires. Ended up having to splice 4 wires. It's all good now. I would post pictures but not sure how to do it from my phone.
Kind of a long post but thought I would share.
Use the following suggestions at your own risk. These are steps that worked for me. Your mileage may vary. There are steps that jumper safety features built in to protect operators; only do this if you fully understand what you are doing and know how to return the tractor to a safe operating condition prior to using it.
Steps to troubleshoot a no start condition where the tractor does not attempt to turn over on a bobcat CT230:
Check fuses are not blown fuse panel under ignition switch near firewall.
Check battery is charged; check all connections for corrosion, clean as necessary
Check safety switches are free to move. The safety circuit operates on 12 volts going through a 5-amp fuse. The operational control unit (OPCU) receives 12 volts when the switch is closed. Each switch is wired in parallel to the OPCU.
Safety switches on CT230 that affect starting:
Travel pedal switch located under floorboard below travel pedal. Sometimes rocks or twigs get stuck between switch and plate preventing plate from returning to close switch contact.
Rear PTO switch should show PTO symbol on dash when PTO is engaged or when switch is not closed. With tractor off and Key in run engage and disengage PTO to verify light changes each time to verify switch is working correctly. Switch is located at end of PTO handle between wheel well and transmission.
Mid PTO switch should show PTO symbol on dash when engaged. Tractors without a mid PTO will be prewired for mid PTO. It is located near the rear PTO switch and has a jumper to maintain 12 volts to the Operational control unit. This jumper can be pulled to verify mid PTO light turns on to verify that part of the circuit, then re-install jumper.
Seat switch located under seat.
Check voltage is making it to the starter relay as follows:
Have someone sitting in the seat to make up the safety switch or jumper the seat switch for testing, ensure PTO痴 are not engaged and travel pedal not forward or reverse.
Pull engine start relay located in engine compartment on right side as you are sitting on the tractor. It is the first of 3 relays and one controller on the firewall.
Check for 12 volts at the blue/black wire in the connector for the relay when key switch is in the start position.
If 12 volts is present, it is likely the relay is faulty. To test if the relay is faulty you could swap the relay with the preheat relay which is the 3rd relay over on the firewall. Turn key on and see if the glow plugs light with switch in run position. If they do not light up, the relay is bad.
The tractor starter can be jumpered by placing wire between the red/blue and the red wire in the connector for the start relay. This acts just like taking the key switch to the start position so do not leave the jumper installed once the tractor is running as the starter will remain engaged.
If there is 12 volts at the Blue/Black wire and the tractor will not turn over by jumpering across the Red/Blue and the Red wire it is likely the issue is in the starter.
If 12 Volts is not present on the Blue/Black wire in the start relay connector, it is likely a safety switch not sending 12 volts to the OPCU. Continue to test each safety switch.
To test if each switch is closing and opening using a voltmeter do the following?
Locate the Operational control unit located under the left side of the tractor as you are sitting on the tractor. It is a black box about 4 x 4 by 1? It is mounted on the transmission casing under the seat. There is a 16-pin connector going in the bottom of the OPCU. Follow the wiring harness while under the tractor to the transmission and you will likely run into the OPCU.
Key must be in the Run position to perform the following tests:
Check for 12 volts at each of the following locations.
Red/blue wire this is the 12 volts coming from the fuse panel feeding safety switches. 1st wire from right with connector removed from OPCU. If 12 volts is not present here the rest of the tests will not be able to be performed. If 12 volts is not present then check 5-amp fuse installed with clean contacts. Fuse in the location with the picture of the computer. Check resistance between fuse block and OPCU.
Seat Switch Have someone sitting in seat and check 12 volts on yellow wire. Should be 5th wire from the right.
Mid-PTO switch Yellow/blue wire. 4th wire from right. Should have 12 volts here even if tractor is not equipped with mit-PTO as the tractor comes pre-wired.
Rear PTO switch Yellow/black wire. 3rd wire from right
Travel pedal switch - Yellow/white wire. 2nd wire from right.
If 12 volts could not be obtained at each of the locations there is likely a break in the wire from the switch to the OPCU. Check resistance between the switch and the OPCU and look for breaks along the wire harness.
Return tractor to safe operating condition as follows:
Repair any issues discovered during troubleshooting.
Ensure seat safety switch is installed and wires connected.
Ensure travel pedal safety switch installed with wires connected.
Ensure PTO switch installed with wires connected.
Ensure OPCU 16 pin connector installed and ground wire connected if removed while troubleshooting.
Best of luck in troubleshooting
Here is what I found when troubleshooting my no start condition.
/ CT230 electrical issue #15
Nice write up, thanks for taking the time to share with pictures even. :thumbsup:
/ CT230 electrical issue #16
Thanks for the information. I will book mark this page for the future.
/ CT230 electrical issue #17
Yeah thanks for doing this very helpful for future reference.
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
US ELECTRICAL TOOL CO.-500B BALL BEARING GRINDER (A64280)
US ELECTRICAL TOOL...
2019 PITTS LB35-33CS CUSTOM DELUXE LOWBOY TRL (A64276)
2019 PITTS...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
Challenger MT800/MT800B Series Tractor Service and Parts Manuals (A63117)
Challenger...
