Front Axle shim 2032R
   / Front Axle shim 2032R #1
Catman8
Gold Member
California
Massey Ferguson 30B, John Deere 2032R
I was greasing the front axle on my JD2032R and noticed this shim and it looks out of place.
   / Front Axle shim 2032R #2
Sure does.. loosen the bolts and slide it back may be a good idea.
But make sure the result is the correct adjustment.
   / Front Axle shim 2032R #5
Thanks for the adjustment directions, I'm curious, what is the purpose of that thin piece of metal. I'm guessing it must be slotted all the way to the end we can't see because if it wasn't the four bolts would hold it in place.
The thin piece of metal is the shim. One or more of them are used to set the proper axle bushing free play. The slots allows it to slide over the bolts. Tightening the bolts sandwiches it in place.
Update: John Deere came out to my property and pushed the shim back down and tightened the bolts that were loose, he did not check the measurement between the Axle housing and the bushing, when I get a chance I will check it myself to make sure it's correct. Tractor was under warranty so I thought I would see how quick they would respond.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A55973)
2019 John Deere...
403 (A52706)
403 (A52706)
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
TANK MANIFOLD (A55745)
