Found a local 5030 to purchase....Needs some TLC....thoughts please
/ Found a local 5030 to purchase....Needs some TLC....thoughts please #1
clsmith
Hello all,
I went and looked at a local 5030 mfwd that I'm thinking of purchasing. Here's what I saw and I would appreciate anything else I need to check and any other insight that can be offered. It needs some TLC.....seat, top and front tires especially. I tried all high and low gears along with the shuttle forward and reverse. it seemed to stay in all gears and didn't grind going in an out. The clutch felt good however in what i thought was a high gear i couldn't choke the tractor down because its going to need rear brakes on each side. I engaged the pto and turned as i would have expected but i honestly don't think it quit turning when i engaged the clutch. if someone could offer me some testing techniques i would appreciative. i'm not sure whether this tractor has a 1 or 2 stage clutch on it. The tractor overall was pretty greasy so it will need a good pressure washing. the meter showed like 3600 hours but the guy didn't know if it really worked or not. It looks likes these tractors normally go for around 15k if they are in really good shape....I'm thinking i can get this one for around 7k. thoughts on that? I currently have a 3000 and my mechanic rebuilt the lift a few years back and its jumping again. He says that going to happen (and it will have to be rebuilt every few years if I don't want it to jump), because the parts they have to use now aren't original Ford parts and do not hold up as long. Am I going to run into the same thing not or down the road with this model Ford? Thanks in advance for any info you all can offer. Oh, I checked the oil and it did not have a burnt smell, of course it was black, but as I read diesel oil is going to be that way.
Thanks,
Clay
/ Found a local 5030 to purchase....Needs some TLC....thoughts please #2
The PTO is independent, so there is no two-stage clutch. Just engage the lever, and it runs. I would think the brakes could be adjusted.
/ Found a local 5030 to purchase....Needs some TLC....thoughts please #3
Are you buying from an individual and do you know the history?
ok Thanks for that info. With it being independent, shouldn't it stop rotating when I press the clutch in or not? I was thinking it would.....
I don't know the history as its is on a local auction yard. The owner of the Auction company said the tractor came from a local farmer that is retiring.
/ Found a local 5030 to purchase....Needs some TLC....thoughts please #6
Sounds like you have a mechanic you trust and have used in the past. Call him or her and pay them an hour or two worth of time to evaluate the machine and offer advice. The mechanic should have a good idea what to look for on that specific model.
/ Found a local 5030 to purchase....Needs some TLC....thoughts please #7
We have one of these in 2wd that we have had for years, very tough tractor that has given us no problem other than being a bear to start in cold weather.
/ Found a local 5030 to purchase....Needs some TLC....thoughts please #8
"a bear to start in cold weather" ??????
Augusta , Ga. average winter low temp. is shown as being 55.5F
Certainly the lowest will be somewhat colder.
RECORD low is -4F, .... but that was in 1899 .....117 years ago!
You really should not have any starting difficulties.
Perhaps it needs a hug.
I do, He's an older guy and wants stuff brought to him lol. Thanks for the reply
Really?? I went and looked at this tractor this past saturday and it was 32 degrees that morning and it started right up. that let me know the pump and injectors had to be in right good shape.
Topcat ECSSSTG200 (A60463)
Topcat ECSSSTG200...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A60352)
2019 Allmand...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
