Top Link questions
/ Top Link questions #21
Makes sense. I've never brush hogged but I've had hydraulic TnT for 20 plus years. All I could think of is trying to lift the box scraper to reset and this wet noodle behind me is just flopping around. I guess with the wheel behind the mower deck and no float built into the Implement float would be a must.
What 3pt attachments do you use on a regular basis?
/ Top Link questions #22
I want my hydraulic top link in the center of it's throw when on level ground. I want the ability to lengthen and allow my attachment to droop as much as possible. I also want the ability to shorten and allow my attachment to raise as much as possible. Not sure why I would want the cylinder to be near the end or it's stroke either way when operating under normal conditions?
That's how I built mine Richard, I'm an equal opportunity employer:laughing:
Well I think I'm going to go ahead and buy the link i posted earlier. I'm fairly confident i dont have float capability on the tractor end so i won't be taking away any capabilities there. I'm going to assume the quick connect is a 1/2 iso 5675, as those seem to be the most common from what i read.
In looking at the connectors/hoses i find i have options: NPT, JIC, and the link comes BSP. Which of these are prefered? and which require pipe tape/liquid sealant?
Big thanks to ovrszd,RNeumann, Rustyiron and LD1. You guys were all a big help. I got everything ordered and I can't wait to try to get it all together and hooked up.
/ Top Link questions #27
The box scraper with hydraulic rippers 99.9% of the time. My little video in the beginning of this post shows my reasoning for the shorter "up" stroke. But basically I like to load the box scraper with new road material and slowly lift the front of the box (extend the ram) to meter out material as I go. Then if I run into something that needs a deeper more aggressive cut I will tilt the box as much as I can and go backwards. The added up stroke only digs the front of the box into the ground and lifts the cutting blades- completely useless for what I do.
I can see the reasoning for equal lengths when level and that is how my new tractor came. It took about 2' of running to realize it wasn't for me though. I took it back and my dealer gave me the next length longer ram.
BTW- my experience with the tractor before this new one and moving to Idaho was construction. I have never ran anything on a 3 point except a box- and my first experience was with hydraulic top and tilt. That ruined me as I was spoiled from day one! All these other attachments are new to me...which is why I asked. Thx for sharing- I enjoy the lessons!
/ Top Link questions #28
If you don't post pictures it didn't happen!!!! :)
/ Top Link questions #29
For bush hogging, I like to be able to raise the rear of the mower up real high (for the big stuff that you shouldn't really be mowing :D) backing into your work, lowering, then pulling out, therefore wanting the t/l the opposite of your situation. Like you said, what implements will be used.
This can be hard on a PTO shaft if you get too crazy. Mowers usually have long ones which helps. (reminds me of running a baler! :yell: ) ISZ
It's not a very good pic, but here it is
/ Top Link questions #31
Nice work!
If those hoses start to seem like they're kinking on you (well, you should catch them before they actually kink) you might consider rotating that equalizer(?) tube (I checked with the folks at Surplus Center and they said it was fine to rotate this):
Of course, I've got 90 degree fittings there. I was concerned about the fittings + hoses sticking getting jammed up against that top-link holder bracket (I'll remove that bracket when I get my quick hitch).
I don't recall running across anyone else that's done this.
Please ignore/excuse the temporary top-link support!
Nice work!
I am definitely going to do this. I already accidentally knocked the hose against the bracket when I lifted the 3pt all the way. I was planning on cutting off the bracket, but I think rotating will be better. Was it simple to rotate? I am a complete hydraulic novice. I think I may need longer hoses too, but I want to try rotating that block like you did.
/ Top Link questions #33
Just loosen the nuts on the ends of the pipe, rotate the pipe and block assembly and then tighten up. I haven't yet used this (only tested), but I am sure that it's the ticket for me.
/ Top Link questions #34
No cutting of the bracket is needed, just remove the two bolts holding it on. Also no issue with rotating the check valve block for clearance either.
43018CFL (A59228)
43018CFL (A59228)
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
208315 (A58376)
208315 (A58376)
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2011 Nissan Sentra Sedan (A61574)
2011 Nissan Sentra...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
