Fan Belt
/ Fan Belt #1
Tlysflys
Member
Kubotta M5040
My toolcat overheated - the fan belt broke and this is the second time in 6 months. This one was from NAPA. Any advice regarding the best belt to use and why it might brake so soon? Mine is a 2011 model 5600 serial number A94Y11588
Thanks for your help.
/ Fan Belt #2
If the belt is breaking either some thing isn't lined up correctly or there's a bad bearing some place.
/ Fan Belt #3
As Billrog stated or over tighten of belt.
/ Fan Belt #5
Check the alternator mounts. Make sure both top and bottom are tight, no cracks in the mount, and the pulley is aligned correctly with the crank and water pump pulleys.
/ Fan Belt
Thanks for the advice. I succeed in mounting the belt, although it took me several hours, as the access is very tight. Maybe there is a better way, but the access on my F-series is very, very tight.
My local Bobcat did not have the fan belt in stock, so used a NAPA belt (like last time).
As best as I can tell, the most likely cause of the belt break is that a twig got stuck into the engine compartment (I was cutting blackthorn when it happened and found a broken twig in the engine compartment). Did anybody experiment with closing the opening on the bottom to prevent twigs from getting into the engine compartment?
TL
