What kind of jig saw blade to use to cut plexiglass or another cutting method
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
I need to cut some plexiglass, I do not know of a plexiglass cutting forum and am on here a lot so asking here.
In my past experience too fast a blade speed will melt the plexi so I plan to use my variable speed jig saw, would a fine or coarse tooth clade be better? I am thinking fine.
or should I score it like they do at the hardware store? I do not have a fancy machine like them but I guess I could use a metal straight edge and a razor knife and score it 10-20 times?
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #2
I just use a jigsaw with a metal blade I cut fast no melting just a lot of the dust stays on the edge nock off with a straight edge.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #3
I use a finish cut wood blade (very little tooth offset) and a slow speed.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #4
I just cut some last week with what ever blade was in the table saw. It was maybe a 24 tooth carbide blade 10" and fed it slow. With a jig saw, I'd put down some removable masking tape on the material if it does not still have the protective sheet, it will scratch & mar very easy with all the shaking & vibration from a jig saw.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #5
Use a fine tooth blade for hard woods or metal, also putting a strip of 2" masking tape over the cut will let you draw a cut line, prevent edge chipping, and shoe scuffing from the saw.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #6
I also use a grinder with a cut off wheel.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #7
I use a fine metal blade in my circular saw installed in reverse, it also works well on metal roofing..
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #8
I cut plexi-glass and other plastics such as styrene light lenses this way. If final size is very important, cut it oversize and trim later or use a router.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #9
Put a strip of masking tape where you wish to cut and you can use a table saw with a zero clearance insert or if a jig saw keep the speed slow enough to avoid melting.
   / What kind of jig saw blade to use to cut plexiglass or another cutting method #10
I use my table saw with a blade for plywood on it and feed slowly.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2011 BMW 128i Convertible (A48082)
2011 BMW 128i...
1261 (A50490)
1261 (A50490)
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2011 Kia Optima Sedan (A50860)
2011 Kia Optima...
