If you have a 5000 series Deere and it cranks but won't start, try this first.
   / If you have a 5000 series Deere and it cranks but won't start, try this first.
Here's a repeat for those with this issue; put the new sensor in finger tight or you will break it and have to buy a second one. Finger tight and know how much torque 3 1/2 ft lbs is.
   / If you have a 5000 series Deere and it cranks but won't start, try this first. #32
THANK YOU THANK YOU same kind of thing only different 2210 JD ,my Airedale pete thinks your great bmryer
Life is good when the dog gives you a thumbs up...
   / If you have a 5000 series Deere and it cranks but won't start, try this first. #34
so I thought that was it, went out last night 7:30 pm. when I read the thread. puled the plug on the coolant sensor 1 wire , turned over started just fine .Today call for the part order part JD ch15516 $ 41.00 ok .thought that was it now even with plug back in and fuse does not blow with plug in or out oh ****
bmryer
bmryer
That's typical. relax, $41 won't break the bank and I've never heard of any other failure-to-start-yet-blow-the-fuse-thing for this tractor. Don't overthink it---maybe have a brew and watch The Weather Channel.
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2008 International Bucket Truck (A55973)
2008 International...
SARLO MOWER (A55758)
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
Hose Reel (A55758)
Hose Reel (A55758)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
